It would be foolish to run an engine at full throttle all the time. (Even though I have heard boaters and mechanics say the opposite). The engine life will be something like 10% of what it should be. That is often why you see relatively new boats being repowered. So, maximum speed would be foolish for everyday use, but good to know.
Cruising speed has been well defined above. Some may prefer to cruise even slower, but that would not be the boat's cruising speed. An efficient cruising speed given fuel consumption, and boat performance, miles per gallon at that speed, and the manufacturers recommendation all factors in. The same engine speed in different boats will, of course, produce different cruise speeds. Also good to know, but as noted, sometimes optimistically reported.
And while diesels may be only a few hundred rpm off of top speed, their top speed is also lower (2400-3000 rpm), so the percentage difference is about the same as gas.
Finally, I have to comment on the new gas engines that are rated with higer HP than expected and have higher max rpm ratings. These often rate max rpm at about 5200. For one thing, this is too high for these engines - especially for prolonged running. And, since the HP is only availableat those higher rpms, it is really unusable. This is probably more of a marketing hype idea than anything nautical, and is why some boaters are dissappointed with their engine's power.
