Cummins 370/420
Ductboy
I am looking at a used boat that is advertised as having the "heavier duty" 420hp Cummins as oposed to the 370hp motor that was standard in this specific boat when it was built in 1998.
My question is this. The 420 seems to be a wound up version of the same 5.9 359 ci block used to make the 370 and several other smaller and larger hp motors (as low as 270 and as high as 480hp in the current electronic versions).
Wouldn't the fact that the engine is producing 50 more hp from the same block make it less heavy duty?
Is there any reason for me to think that these engines would be more or less reliable than my previuos Yanmar 350's. Any maintenance issues with the Cummins vs. the Yanmars?
Dan
Any opinion on these motors would be helpful.
I dont think the 5.9l was rated at 420 in 98. I suspect you are looking at an 8.3l. Too bad you dont incluse the engine models. HP ratings overlap greatly.
I agree with Bruce on this one, - at 420HP it’s most likely a 8.3 “C” engine, not the 5.9- I had the 450hp version of the C in my last boat a 1997 Formula-it had over 1300 hard hours when I sold it & was running great
My opinion it’s the best engine available for its size and at 505Ci/420hp, it .83HP per CI
Cummins/MerCruiser is now squeezing 600HP out of the 8.3 [:-bigeyes]
Dan We have had 450C'c for yrs, with not one problem. Realize not identical engine, but Cummins has worked for us.
Thanks for the information. I have only been able to get basic specs on the boat so far. The listing shows that the boat has 420's, so I checked the current Cummins Marine website and came up with the closest current Electronic 425hp rating coming from the 5.9.
I see that the 450C mechanical motor (8.3) is still available. That would make more sense with the sellers 'heavy duty' comment.
The boat is a 98, and the motors only have about 275hrs which I understand could be good or bad.
Thanks again
