Cutting double braided dock lines
Twin Buoys
What's the trick to cutting double braid nylon dock lines? How would you seal the end (keep it from fraying)? I need to shorten the length of my bow lines a bit. Thanks in advance.
If you don't have the cutter, or torch--then bind the end of the line tightly with some masking tape where you are going to cut. Use a very sharp knife and immediately seal the cut end with a cigarette lighter.
tape then cut in middle and dip into plastic pipe glue. cheap
Pipe glue? You're making the Boatswain's Mate cringe...the thing you need to look out for is the core moving within the cover. This isn't just cosmetic - if the core and cover are stretching at different rates than intended, or even one pair of strands has slacked, you're slaughtering the breaking point, hence SWL, of the line.
Red hot metal seals and fuses as it cuts.
Once I can get on a regular keyboard I've a little treatise to compose on VHFs - I'm at work right now and a bit busy, but there are a few points that I think need to be made.
If you push the line down onto a surface the outside braid opens and allows the goop to get inside sticking the whole mess together.
I prefer to use a very tight wipping on end. If not that; I will also tape tightly & cut down center of taped area with very sharp device. Whatever you do, don't SWL.
Nothing like a milion ways to skin a cat!!! I used a kitchen steak knife [which remains in the tool box] and heat ed it on my grill. Sealed and bonded the end. Whipping with tape first would have been good if I'd thought of it. I can't wait to try the PVC glue. I love the idea of the color on the ends. I have no life.
