DC Powerd Coffee Maker & Blender
ras737
Has anyone had any luck with these units. I would like to make a cup of coffee or mixed drink without starting the generator.
Don't waste your money on the coffee maker they're pretty much useless unless you're willing to wait 3/4 of an hour for a cup of coffee. The blender I've heard are ok. We had to wire the coffee maker directly to the battery with 4ga cable to get it to brew a pot in under 20 mins. It's quicker to boil the water in a kettle on the stove and use the coffee maker basket & pot.
Do like Rick says and use a manual pour basket, or use a french press, or a stovetop maker.
Why not get a small inverter for the occasional cup of coffee or frozen margarita? I've seen 400 watt inverters at Walmart for about $30. That way, you don't have to fire up the genset, you can just use the battery for a few minutes.
A good practical topic.....
We found our french press to be a bit of a pain with all the mess. I think we are going to go back to an automatic coffee maker with filters so that cleanup will be easier.
We waited 1/2 an hour for the 12 volt electric to make 2 cups. The origo had a tea kettle boiling in minutes and I was poaring boiling water through the melita cone shortly afterwords.
We also like the French press since boiling water is the quickest way to a cup. However, we are like Woodsong and don't like the mess. Tried the freeze dried stuff and didn't like it a bit. If we could find packets of good coffee we would combine those with the press.
You would be a lot better off to install an inverter and then run standard 110v appliances rather then buying 12 volt versions. I would recommend a minimum of 1500 watt inverter.
For the morning coffee without starting the generator what I would do was use a small butane stove. A good old fashioned percolator coffee pot will do a great job in a matter of minutes. I have a thermos pot that has a funnel that a standard coffee filter will go in that I just pour boiling water into, makes the coffee straight into the thermos.
The French press is okay for one or two cups but like woodsong said it can be a pain to clean.
Rod
abdiver, I agree with you! But I wasn't aware of the thermos pot with a funnel contraption. That sounds neat!!! I use a Mr Stove with butane cannister and an aluminum pot. Then I pour the perked coffee into a thermal serving carafe [like in a conference room] to keep it hot all morning.
Where did you get the thermos pot with a funnel contraption and how much did it cost?
Yeah, the press is a bit of a pain to clean. I usually use a rubber cooking spatula and scoop out the grounds into the trash. That gets 95% of them, and the rest I just rinse down the drain.
I might try the carafe/filter idea, that sounds pretty good.
I seriously doubt that a 400 watt inverter will run a coffee maker. I'm guessing that most coffee makers are well above 1000 watts.
12 volt appliances are JUNK, don't waste your money on them.
A 400 watt inverter will not power a coffee maker. Check the back of your coffee pot for the watts and add 10 or 20% for a safety margin.
For example my coffee maker is 900 watts, a 1000 or 1100 inverter would be needed.
I had a 12volt coffee maker once and Chinese water torture is more fun than using that thing!
Well I am happy I asked. I guess I will look into a 1500 watt inverter but I am not sure how practical that will be. Looks like firing up the genset not that difficult after all.
Save your time and just have a beer. It just not for lunch / dinner anymore! :)
For $20 or less you can get an old-fashioned percolator for the stove.
Battery-powered drill works good on the drinks.
I tried one of the 12V coffee makers a couple of times, then I tried making coffee in a percolator while we were still plugged into shore power, then transfering it to the 12V unit to keep it hot when we left the dock to go fishing, then I bought a 2qt thermos and sold the 12V unit at a garage sale.
