I put some gas in the boat today using cans as I often do, but put some in the port tank which I usually don't do with cans, only at a gas dock (since it's the side away from the dock.) Was met with a gas smell in the saloon and cabin which obviouslt triggered an investigation. Turns out it was dripping down from the deck fill or hose (can't see up in there to tell which), so either the fill fitting has rusted through inside or the hose is shot. No boat ride today obviously, everything electrical is disconnected pending repairs.
I want to replace both fittings and both hoses. The hose I found on Boatfix, it looks like the 2 3/8 hose is it, since my for now somewhat crude measurement says it's 2 3/4 OD. But I don't see any deck fills like mine anywhere. The flange OD is 4 3/8 and it has to fit the 2 3/8 hose. Anyone know of a source, or at least a manufacturer? Smaller ones are not going to work with the hole that's already present in my deck, plus I don't want to change the pipe on the tank to work with smaller hose.
Also, what would one seal these fittings and hoses with? There seems to be some sort of hard black goop that's bulged out of the joints now which I can't identify.
