Even when you're not aboard, wasteful as it seems, running the AC may still be the least expensive way to go in the long run. I believe if you have sufficient water under the boat for the AC it is the least expensive way also. A few years ago, with my last boat, the AC pickup was in a place the slip fill in first which meant sucking mud was a regular feature of the system. In an effort to help alleviate the problem I purchased a dehumidifier because when the AC kicked off the mildew would show up in the cabin within a day or two. As you know the FL sun will heat the cabin to over 120 degrees in no time.
The dehumidifier helped, it kept the cabin dry even during our brief rainy season but the strain on the refrigerator and the toll on the heat took on the rest of the stuff, even the TV's was simply too much. Especially the head. Whew, the heat with the salt water flush brought the odor everywhere. Since I never plumbed the dehumidifier or put in on the galley counter (too big) I had to empty it every day and found the emptying, the heat and the smell too big a price to pay for not running the AC.
My current boat has two heads but a fresh water flush and two AC units and I run both. Fortunately the boat always smells fresh, is cool and provides a good place to "gotta go work on the boat for a little bit" type of place. I have the dehumidifier in the garage and it really helps keep it cooler but I still gotta empty it.
Mike, Palm Coast, FL
