detergent through the exhaust??
1984 cobalt
i use the marina del rey (ca) launch ramp and while i was rinsing the salt water out of my outdrive and engine yesterday three really badass scaarab's pulled into the wash out next to me. they put some kind of solvent into their engines and suds started pouring out of their exhausts with the fresh water. i have heard of running bleach through the outdrive and engine after taking it out of salt water, but is there some kind of eco-friendly detergent that i can use? i am not a tree hugger, but i also surf in los angeles and the water is polluted enough. i have a volvo 280 outdrive. thank you for the always helpful info.
Why would you want to use a detergent of any sort?
Fresh water should do everything you need done. And if you are more worried about salt tha I am, you could use "Salt-Away".
I definitely would -NOT- use bleach. a) why? b) it tears up aluminum, and inthis instance you increase the temp, which would make for even more damage.
use water...
I wonder if they activated a NeutraSalt system...
I use Salt Away on my RWC old Chris. I suds up like crazy. They say it is biodergareable so no worries.
Please do not use bleach for all the reasons stated above. If I'm not mistaken, doesn't bleach have some form of salt in it? I would think you would be trying to use salt to get rid of salt. Doesn't make any sense to me but I am not a chemist.
"sodium hypochlorite" = household bleach. Yes, sodium = salt! Good catch KiDa!
thanks guys, bleach through my engine/outdrive was never an option. i appreciate your input. i think i will stay with fresh water rinsing. until next time...
bleach does not make suds unless there was another additive in it.
