Dimming the gauges
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
So I was taking a night cruise on Raystown Lake last Sunday evening after watching the fireworks, and couldn't see a darn thing when I sat down in the helm seat due to the reflection of the gauges in the windshield. I had to put up the seat bolster and fend off the bugs with my face for the 14 mile return trip.
Does anyone have any ideas on how to rig a dimmer or even shut off the gauge lights while still having my nav lights on, or am I looking at a big rewire job under the dash?
By the way, night cruising was really cool. I created a track log on my little handheld GPS on the way down (in the daytime), and then followed it back at night. Plus, there was a near full moon that allowed me to see the shore pretty well.
Bob, my larson has a round knob on the left side of the wheel which will dim the dashboard lights.
You may want to check if you have one.
Jeff, no, I don't have one like that.
Bill, is there a hot wire to each gauge that is separate from the hot wire that the gauge needs to work? Would I run ALL those hot wires through that one dimmer? They're Faria gauges, if that matters.
You used to have one:
"I had to put up the seat bolster and fend off the bugs with my face for the 14 mile return trip."
That's why we took it out ;)
Your lights should all be on the same breaker. You can put any 12V dimmer down stream from the fuse. Probably at radio shack for less than $10. Watch out for the wattage capacity of the dimmer.
There is usually one hot wire that powers all of the instrument lamps. The dimmer goes in this wire. It also comes with "instructions", whatever those are... ;)
Normally, it would go: switch -> lamp(s), you want switch -> dimmer -> lamp(s)
take all the bulbs out, paint 'em with red fingernail polish, and put 'em back.
I lower all my lights when cruising at night, but I still never sit down and look through the windshield. You need to be on the top of your game in the dark. Once I left the plastic up for a short night run and ripped it down quickly when I wasn't comfortable with what I could and could not see.
The red instrument lamps are available at Advance Auto Parts [or whatever Parts America is called in your town] and oddly the two-pack is less expensive than a two-pack of clear ones. I was concerned I'd lose pointer contrast in my white Faria gauges but it didn't happen. I like the red a LOT.
I changed my guage lights to red LED. They're not quite as bright as incandescent bulbs and they're a much deeper red. They should last just about forever. I got mine from superbrightleds dot com.
No I'm not home. I'm at work.
Good idea on the towel thingy. I'll give that a try next time. Maybe if I'm feeling bored next winter, I'll give one of those dimmers a try. Thanks for the suggestions, all.
Bob,
I must admit that at times your humor has cracked me up, but I simply don't understand you. You asked what appears to be a serious question, multiple people provide good responses to you about how to deal with your problem and your response is:
It makes one wonder whether it is worth the time to respond to your questions. Hope the towel thingy works out for you.
Absoloot,
I don't understand why you don't understand me. I'm not trying to be funny, I REALLY don't. I have been checking back on this thread quite often, I have considered many of the suggestions, including changing the bulbs and painting the bulbs, and I think the quick and easy fix is the towel idea. I hadn't thought of that at the time. But, I think the best fix is to install the dimmer. That way, I can dim them down when underway, light them up slightly as needed to check the gauges, then dim them back out again.
I'm just wondering how big of a job that is. I don't think I'll do it during the season, as every spare few hours we have we try to get out ON the boat, not work on the boat. That's why I said I'd do it over the winter, maybe.
Why wouldn't my questions be worth responding to?
