Dinghy Chocks
tlaw7
I need to put my dinghy up top and want to know if anyone can recommend chocks. Looking at Weaver,for instance. They're all ridiculously expensive!
Thanks.
Could you define what you consider a reasonable price to be, and then maybe we can start from there. You might want to call around to some boatyards and consignment stores and see if they have any takeoffs.
George
Hatteras 56MY.
I went to a local tower builder and had two parallel bars made for $250. I gave the shop a simple drawing. After installing, I wanted a cross member to prevent them from being spread apart by the slope of the dinghy hull. I am using some webbing to hold them together until I can get a welder to put a cross member on while it is on the boat.
That was going to be my suggestion. If you can make them lower you won't need a cross brace. You can also cover the horizontal parts of the tubes with vinyl hose to act as chafe protection. As well as helping to keep the tender from sliding around.
One of the best features of using pipes for chalks is the fact that the are more universal. In that they are not custom cut to match the outline of a specific hull form.
That's what I was looking for! I could almost use pre-made side rails. Anyway, got a good metal guy nearby and I want a u-shaped bracket for a back seat, too.
Thanks,guys. You saved me mucho dinero!
Deerows and Capt. Bill1,
Forgot to ask, if you see this, how do you decide on the length of the pipes? My Whaler is 11 feet long. I can guess but thought I would pick your brains a little more on this.
Thanks a lot! Weaver wants about $650 for four mini-jackstands (widow-makers). Great company, but WoW!
For an 11 foot Whaler I think you would want them to be around 8-9 feet long. Kind of depends on at what point the hull starts to curve up towards the bow.
I did a mock-up using 2x8 dock boards (hurricane debris) but you can use a straight edge (6' level?). My length was determined by the hull shape and the location of the hatches. I thru bolted mine with backing plates. I had to take down my headliner to do this. My headliner was stained and needed replacing anyway. Weaver makes some toggle bolts "for installing Weaver Davits and Weaver Chock Systems on integrated swim platform or difficult areas to get into". Since my racks are tall, have some sideways force on them, and are mounted on the foredeck, I decided that I wanted a strong backing plate.
holy moly, what timing. I have 4 brandy new weaver swivel chocks for sale! email me licciardisalrb2@gr5thotmail.com
hey, how come my email got butchered?
who ever is looking for chocks, you can get all set of 4 for 100.00
518 441 8470
Originally posted by deerows
I went to a local tower builder and had two parallel bars made for $60. I gave the shop a simple drawing. After installing, I wanted a cross member to prevent them from being spread apart by the slope of the dinghy hull. I am using some webbing to hold them together until I can get a welder to put a cross member on while it is on the boat.
Very sharp. Looks good!
it's critical that whatever you use gets braced, especially for something placed at the bow where efforts are higher.
a few months ago, I was also "chocked" by the cost when I needed a set to secure a PWC. I designed and made them myself with 3/4" starboard.
Very simple...
- get a 24" by 48" piece, and two 6" by 48" pieces.
- cut two holes in the middle of the larger piece, about 15" by 15"
- use these cutout to cut triangular braces, 6" by 3"
- screw the 6" by 48" to the base, just outside the cutouts (I used SS screws, recessing the heads)
- add the braces, also screwed in. I put 3 outside, 3 inside.
- finish with some rubber guard.
- fasten to the deck
simple, about $100 of starboard, a few hours with hand tools (circular and jiw saw, planner/sanding block to smooth the edges). I know starboard isnt' a structural material but in this configuration there are no issues, it's rock solid, never going to need painting or rot!
Great Ideas! The concern I have with the Weaver stands is the concentration of weight. I think I'll do rails or the starboard config.
I've been registered on this board for a few years and have gotten a lot of good info (and yuks!). However, based on all the $$$$ I have saved from asking this question, I'm sending in my official enrollment today.
Thanks, guys!
Mark,
When we bought our boat, the dinghy was set up on similar parallel bars with NO cross members. It's been 8 years and the bars haven't spread a bit. I wouldn't worry about adding crossbars, I think it's overkill. JMHO, YMMV
I was looking for another receipt yesterday and found the receipt for my dinghy chocks. The price was $250, not $60. I'm going to edit my post to correct the cost.
They say that the second thing to go is your memory, and I can't remember what the first thing to go is!
Is there any glue that works with starboard, perhaps something that would weld the contacting surfaces like PVC glue welds PVC pipe?
Yes, Starboard, and I think someone elses now, has a glue for their product. With the Starboard glue surfaces have to be annealed first before gluing.
there is a special glue, never used it, i prefer mechanical fasteners, especially for this application.
tlaw; the solution for your application is driven by a couple things; the speed at which you travel, the weight of the tender & the strenght of the deck it is sitting on. anyone can come up with an inexpensive solution that will work while the boat is at rest. for example pascal's solution is probably ideal for his boat as it is a relatively stable and slow moving boat, unless it were out in seas big enough to clear the bow it is unlikely to see significant forces exerted on it. a sport fish moving at 30 mph is actually moving at approx 53' per second. if you multiply the mass (approx 750 lbs) by the speed you get an idea how much acceleration is involved when that boat comes off the top of a wave. the lateral and vertical acceleration coming off waves could easily momentarily approach the forward motion.
having someone mfg chocks for your specific application may not be cheap in the short run, but may be money well spent if the tender comes loose on you. there are plenty of mfg's out there that engineer their product to fit your specific application. unless you know an engineer to work it out on your own, its def easier to go to a firm that has already done the math.
Vic, actually the chocks I shown are on the boat deck of a 23kt cruise boat... so being about 18' above the water, the acceleration forces are fairly high. In beam seas, due to the height, they are probably the forces are as high those encountered at the bow of a sportfish in head seas.
but the chocks only hold the PWC level, the PWC is secured by crossed straps to the deck, not to the chocks.
