Dinghy hoist?
jaj63207
I have this posted under the Carver forum but would like more exposure.I have a 1986 Carver aft cabin. I have purchased a 100 lb, 9' inflatable that I want to store on the foredeck.The St Croix hoist just looks a little flimsy and supporting with the hand rail doesn't sound like the best way to go.I found this hoist on ebay. My concen is that it is made of steel. Any thoughts on corrosion problem if I painted it with two part epoxy and replaced hardware with stainless? All opinions welcomed. Thanks,
Jimmy
http://cgi.ebay.com/ebaymotors/ws/e...RK:MEWA:IT&viewitem=&item=150104270636&rd=1,1
What are you planning on mounting it to?
Ideally it would be mounted as close to the gunwale as possible to reduce the moment arm (leverage) as it reaches out to pick up the dinghy. This may put it in an awkard location for people moving about the bow. Mounting the lift inboard more will provide clear access along the rail for people moving about but it will dramatically increase the moment forces (rotational leverage) at the base of the mount. I.E., it will put a lot more forces that will want to rip the entire hoist off the boat.
You will need to consider that the forces on the hoist can be far greater than the 100 lbs that the dinghy weighs. Will it have an engine? Gas tank? A couple of life jackets to keep it legal? Don't forget the few gallons of water that will surely find its way into the dinghy.
Once you have attached the dinghy to the hoist you are now at the mercy of the conditions. If your boat is rocking a bit then the hoist could unexpectedly yank the dinghy out of the water and exhert a major amout of force on the lifting cable to do that.
Just out of curiosity, how will you attach the dinghy to the lifting cable? I would think that you would want to have the dinghy up by the bow, which means that you may need to be in it to get it up there and attach the cable. Now if the boat rocks it might suddenly lift the boat with you in it, a significant increase in the weight. How do you get out of the dinghy and back on the boat? Can you climb over the rail up towards the bow? Lifting the dinghy with you in it is not a good idea.....
The bottom line is that the section of the deck where you mount this hoist will need to be very strong!
Rod
To lift the dingy out of the water and over the rail onto the fordeck you will need to raise the dingy 8 feet or so. That lift looks to me like it will only do the job on a short lift, such as from the water to the swim step. I carry my skiff up on the top of the boat behind the pilot house. I'm set up with a boom, manual wench to raise and lower the boom and a 12 volt wench used to lift the dingy. I am always amazed at how heavy a dingy and an outboad can be. My old skiff was a 12 foot Achallies with a 25 hp outboard. I hated that SOB. Just replaced it with a 12 Aluminum Lund and a 15 hp 2 cyl. Really looking foreward to using the lighter boat.
I would mount it just inside the cap rail on the flat foredeck(close as possible to the outside). I would attach a small multiple block out where lifting hook is. I still haven't figured out what to to about hooking/unhooking the hook from the lifting harness. A member on the Carver forum said he climbs back over the bow after hooking/unhooking. I'll have to think about that.. Any thoughts on the corrosion issue?
Jimmy
This sounds like an accident waiting to happen.
Bert: Please explain. I would appreciate thoughts on why it is not a workable idea.
Jimmy
Whats the problem with putting it on the swim platform?
Faster now but still steady
I may end up doing that if I can't find a way to store it at the pointy end. I'd just rather have it forward, I guess so we're not looking at all the time and it would be a little more difficult for anyone else to take it.
Jimmy
Jimmy,
In my opinion that davit would look like crap on your boat, would have rust problems and may not be capable of lifting the dink high enough. I'd take a look at Roskelly Olsen davits. Their simplest model should do just what you are looking for. I think that you'll have to take the post down thru the deck so that you can make an attachment to something solid (see my post on the Carver forum) If you've got extra money, I'd try and get one of the davits thats folds down flat when stowed for better appearance on your boat.
On my 45' Californian I bought an Atkins & Hoyle manual davit with a sail boat winch for the fore deck where my 8.5' Zodiac with a 5 hp Johnson sat. It is removable and to keep the bow rail from stressing I used a strap at a 45 degree angle from the rail to the Weaver chocks that the dinghy sat on. That kept the rail rigid while hoisting the dinghy aboard. Not the best system, but cheap. They are a Canadian company.
