Originally posted by RWS
Not having to flush the dinghy motor sounds like a great idea to me, however it looks like I will be limited to a 2 hp Honda 4 strok
Neither size of the motor or it being a two verses four stroke will make any difference on the need to flush the motor.
Many will argue that it is unnecessary to flush an outboard at all. Indeed, I know of a lot of outboards that live in salt water and never get flushed. Will it last longer if you flush it? Maybe. Will it provide adequate service if you don't flush it? Probably.
One thing that you should consider about the really small outboards is the fuel tank. It is common for the small engines to have a really tiny gas tank built right on the engine. I find this to be much more of a disavantage than an advantage.
The issues:
IT holds so little fuel that you will need to refill the tank often. This means carrying a gas can on the cruiser. It also means transfering fuel from a gas can to a dingy bobbing around in the water, usually from a very awkward position.
Second issue: stowing the motor. There will be gas left over in the tank. If the tank is more than half full it will probably leak out the cap/vent when you lay the motor down. Trying to drain the tank back into the gas can be another hassle, and prone to gas spillage.
Third issue: The tank doesn't hold enough. You can't go for an all day putt around the harbor.
Life is much better with an external gas tank,.
Rod
