Dinghy Motors
manticore999
We're going to get a small infalatable soon. We want to be able to take our dog to shore to do her 'business' and also use it to explore a little. We're getting a small one and I'm wondering about powering it. I really don't want the hassle of gas - fumes, transporting, storing, etc. so I'm considering just using an electric trolling motor. I figure I could just charge it overnight and use it during the day for the dog and what-not. The dinghy will be around 8' - definitely a small one. My question is this - does anyone have an idea of how long a battery charge will last? I realize the type/size of motor and size of battery make a huge difference but I'm wondering if anyone has experience doing this and could just provide some info.
Thanks!
You say you don't want the hassle of a gas engine? Seems to me, hooking up an electric to a battery, charging the battery, etc. is more hassle than a gas engine. Heck, the battery alone will probably weigh more than a small 2hp gas engine.
True - but I won't have to fill up a gas can, transport it to the boat, store it somewhere, worry about fumes from the motor and the gas can when not in use, etc. I have a 'smallish' boat and storage is at a premium.
I store my fuel within the anchor locker. Just b/c your initial thought is just to shuttle the mutt to shore, you do not know what your needs maybe in the next few years. (explore a creek etc)
Go with a gas motor. You will not regret your decision.
we have a 28 chap. smallest achilles, 30lb trolling mtr, minkota chgr, blue top sealed gel battery, and the oars, been using for 3yrs on bays at the lake---no big waves,current, or distance. sealed gel won't leak if it gets tipped over by the kids. battery life hasn't been a problem yet. we also got a small sealed battery (3by7) from a battery store. they said it was for wheel chairs? use it for short trips or as a back up.
Steve, I have a small Avon with a little trolling motor. I got a deep cycle #27 wet cell battery and can putter around on that battery for six or so hours w/o any problems. When I return to the boat, I put it on a trickle charger. I have also used a solar charger when on the hook to trickle charge that battery w/o any problems. I think what you propose will fit your needs perfectly!
Have fun.......
Liz
The wet cell should be used with caution due to possible acid spilling. For a few more $ no worries with the sealed gel.
I keep the battery in a battery box with a secured lid which prevents spills and keeps the battery dry from spray.
I switched to an electric trolling motor a couple years ago and have never looked back. It's easy to "crank" and it ALWAYS starts. The motor itself doesn't weigh much so it is easy to ship and unship. Battery is heavy but since I don't have to balance it on the transom it's not a problem either. I charge it by simply plugging it in to the "mothership's" electrical system.
I use an old MinnKota 24# thrust motor (smallest now is 30#). It'll push my 10' dink AT LEAST three miles (and return) with me and the dog, on a single size 24 deep cycle battery. Obviously a bigger battery or two of them would push you farther. Speed is 3-4 mph... not a record-breaker but it gets there.
I have a diesel boat so not having to mess with gasoline is a plus..
I just received my Minn Kota Riptide last nite with 40lb thrust. After reading all the posts about how much gas motors weighed, I stuck with this 25-pounder...
[:-cowboy]
[:-cowboy]
How much does the battery weigh?
The one which powers the electric trolling motor [Minn Kota Riptide].
The weight of the battery is not that big a deal; you don't have to balance IT on the transom. Most "marine" batteries have a built-in handle;, I just grab mine and set in the boat, wherever. However leaning over the stern and trying to line up a 60# outboard can have it's anxious moments.
Hey Liz - A little off-topic, but where did you get your dinghy? I've been trying to find one under 8' (I only have a 9' beam) and I'm not having a lot of luck!
