Dinghy repair
Type-A
I have a 1998 Merc 270 inflatable (PVC). It's in decent shape other than developing numerous slow leaks (mainly along the floor where it meets the pontoons).
I have tried some PVC glue (forgot the name) and a small kit with the round patches from West Marine.
Other than recommending buying a NEW inflatable, can someone recommend what I can use to repair this or am I wasting my money?
Thanks!
i had an old West by Zodiac roll up which was fine for 4 or 5 years, then the floor started coming apart from the tubes... I tried various glues and kits... could never fix it as there wasn't a contact patch big enough.
I have the same problem. . . after three years, all glue connections are coming apart. I'm going to chuck it and go for a hard body replacement. There are a couple I like. Pascal I believe you recommended the Livingston didn't you? and Ridgid Boats http://www.rigidboats.com/ look good to me.
Try taking it to a reputable inflatable dealer for the repairs. I've had good luck with them when fixing leaks myself was unsuccessful.
It might be less trouble in the long run to just go out and buy a used Hypalon boat, like an Achilles or Avon.
Aquaseal and Cotol 240. It's the 5200 of inflatables, wetsuits, drysuits, et cetera.
There is a material called "inflatable boat sealant" Which you inject into the air chambers. This should take care of the problem, if it is reparable. It is worth the $60 to find out, vs buying a new boat. A slightly different technique is used for just leaking seams. You don't inflate the boat as much, and wipe the material off as it "oozes out" of the seam leaks.
If the seams are giving way, and you cannot re-glue them, then time for a new boat. Yes Hypalon lasts longer, but if you take good care of a PVC boat they will give good service (and this does not include leaving the boat out in the sun and weather)--if you want to do that, then go with Hypalon.
Ahhhh, just one of the reasons I like my hard dinghy. 20 years old, survived 2 children, numerous rock landings & hundreds of miles of towing. Still going strong. There is nothing that some grinding followed by a bit of resin & cloth that cannot be fixed.
I took it there in the fall and they told me that it would cost too much money to repair, that is why I tried to do it myself.
Looks like I'll have to go shopping for a "new to me" dinghy.
I've had great luck repairing dinghies, both Hypalon and pvc.
First, buy a two part adhesive.
Second, the part most people get wrong. Get all the old glue off the dinghy, I use 40 grit on a sanding block, to remove the thick caked on yellow stuff, then a 3m pad soaked in MEK to finish.
all the air must be out of the dinghy, to that the patch or rejoined seams can be squeezed together.
mix up a batch of the adhesive, I use a clean finger to apply it, and spread it out so thin that you can just feel it starting to tack.
wait 20 minutes.
That wasn't 20 minutes, have another beer.
do another thin coat the same way.
another 20 minutes.
last thin coat.
wait another 20.
apply the patch or join the seams, put some weight directly onto the patch.
twelve hours later inflate, but not to full pressure, let it sit for a few hours, the patch will stretch a little.
then fully inflate and you're done.
It's a lot of work to get right, but I'm still using my rib that the tubes had become detached from the bead five years ago.
Also, the dinghy repair stuff that you put inside the tubes is really designed for dinghies that the fabric is so old it's become porous, and air bleeds through it.
One last thing, a dinghy that's got too much damage to repair, can become a work float if you fill it with expanding foam and let it harden.
Best, Joe.
