Dink motors
mx8
I`m sure this has been discussed, and I`m sorry if i`m bringing up anything repetitve but my search didn`t bring up what I was looking for.
I`m looking at a new Nissan 6 hp, four stroke engine for the 8` inflatable floor dinghy. I`m currently using a 4 hp two stroke Yamaha that is 1985 vintage, which starts and runs every year with virtually zero maintenence. The question is will the four stroke have more or less power than "Old Faithful"? The Yamaha will plane with myself in it but thats it, with two people you might as well keep it at just above idle because it won`t go any faster at wfo.
i doubt it will plane with a 6hp. i had to go to 8hp to get my WM sportboat to plane. 9.9 to plane with 2 adults and 3 dogs
I have a 4-stoke 6HP Mercury, and it's not any faster than my friends 2-stroke 5HP. The extra weight of the 4-stroke eats up whatever added power you gain in a one-to-two HP jump.
I say stick with your 4. If I could do it over again, I'd go for a 2-stroke.
I agree with the above... how much of a hurry are you in, anyway?? As long as "old faithful" remains so I'd stay with it. A bigger, heavier motor will be that much more of a hassle putting on/off the dink.
I went the other way; changed my old 4 hp Evinrude for a MinnKota, and have never regretted it.
The weight thing is the reason I`ve stayed with O.F. so long, she weighs 48 lbs. The problem is she just ain`t so pretty anymore, she`s had some cosmetic work, but the "lipstick on a pig" syndrome has taken effect so I`m considering leaving her for a younger model, one I wouldn`t be embarassed to be seen in public with. Oh sure, some would call me shallow, having a crisis, looking for "arm candy" but its cheaper than a red convertible.
I`ve made a connection with a 03 model, 6 h.p. two stroke, I`,m sure she`s a fast mover but way too portly for my taste at 73lbs. The new Nissan 6 four stroke comes in rb2@gr5t 55 lbs so its a little more fuller figured than O.F., I just don`t want to lose performance. Of course i would keep the old flame on the side for backup, there`s no reason burn any bridges.
I'd stick with the 2-stroke for a small dink. You can't touch the power to weight provided by this package. Four strokes are [generally] a bit heavier, have more moving parts and can only be stored in certain positions. If you decide to stay with 2-stroke, get one quick. Many sources are switching over to 4-stroke only.
Thats what I`m finding out, I`d prefer a 6 h.p. two stroke but it`s getting hard to find them.
My 5hp 2-stroke (8.5 ft wood floor) can plane me and the dog/cooler OR Me/daughter/cooler....nothing or nobody else. Any more weight and we have to use displacement speeds. Considered trying an 8x7 prop vs. the 8x8 currently....anyway...
I'd never use a 4stroke on a small dink, unless the davits allow you to leave it on. The added weight, limited storage positions, external fuel tank (for same HP) etc...etc...
I'm looking at the 5 hp 4 stroke Tohatsu. Its 54 pounds I,m not sure I can handle putting it on and taking it off.They dont offer a 2 stroke in 2009.
Joe were selling a small Merc a while back? Did you sell it.
Thanks for the input, I found a 8 h.p. two stroke Johnson, 2005, that should work out. Time to fog out the Yami and put it up in the loft, maybe it will come out again when the grandkids are old enough for their first boat!
I've got a Nissan 8HP 2 stroke on a 9.5 Achilles inflatable. With just me on it, I've had it up to 20 MPH, per GPS.
Make sure you drain all the gas out of the Yamaha and run stabilizer through it, or you'll end up with a gummed up carb.
