Dink on an Express
Tanqueray
I've been thinking about possibly getting a small dink for our Boat to access some shallow anchorages etc.
The problem would be in how to store it while underway. It would have to have to have some sort of a hard bottombecause of the pets claws and oars are just fine....doesn't need a motor. The Boat is a 28ft. Cruisers Inc and although towing it behind is an option it also limits the speed I can travel at.
Any Ideas?
Lots of these:
Some of these:
A bunch of this:
And there you have it.
Here is the prototype:
Seriously, the wooden slat bottom inflatables are great for what you want to do.
How big is your swim platform? Here is my setup on my 30' 2001 Regal 2960 Commodore.
Mine is an 8' 6" Achilles high-pressure floor. Width is 4' 10" which still leaves me enough room to walk across the swim platform.
The davits are the Hurley tip system. With the Yamaha 4hp and 3 gallon fuel tank, the whole thing weighs around 125 pounds.
The high pressure air floor seems very durable...but nots how it would hold up to a cat's claws...maybe if you put something over the floor.
Hope this helps...
-Brian
"Full Circle"
Twin 5.0L Mercruisers with Bravo 3 drives
Nice set-up for your boat but my Transom doesn't allow for such a set-up.
i think the only solution on a boat like this (and most express) is a small roll up with an electric inflator. I used to do that on my 37 express, it's easy to inflate and it's not in your way. I dont' like dinks on the platform, they take too much sapce and are always in your way. The electric inflators work well, rolled up a small dink doens't take much room in its bag.
on the down side, they dont' row well at all! so maybe a hard dink (although often unstable) is your best bet with hinges on the edge of the platform to lift it up
What about up on the Bow...isn't there a system.
A few months ago, I saw a guy that had a rig that slid into something hooked to the railing onto the bow. It was like a portable crane and was able to take the dink and drop it over with ease. When he got back from shore he hooked it back up and hoisted it back to the bow when he got back on the boat. After he secured the dink he pulled the davit from the holder and stored it.
Found something similar to what I saw...
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/31735/377%20710/0/davit/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710&Ne=0&Ntt=davit&Ntk=Primary%20Search&Ntx=mode%20matchallpartial&Nao=0&Ns=0&keyword=davit&isLTokenURL=true&storeNum=6&subdeptNum=625&classNum=626
Can you tow it? I used davits on my express to raise the dink and hold it 'upright', but I'm thinking you may not even have room that if I'm looking at your photo correctly. The boat I have now doesn't really lend itself to that kind of setup, so I've started just towing my dink when I need it. Since you're not going to have an engine on it to worry about perhaps that would work?
it depends on how far you are going with it, the tilt up system is handy and saves deflating the boat, but you lose all access to the swim platform. if you are cruising and need it in/out of the water at each stop, the tilt up is great. if you only need it occasionally on a trip, an inflatable stowed on the bow is out of the way until you need it.
i think the only solution on a boat like this (and most express) is a small roll up with an electric inflator. I used to do that on my 37 express, it's easy to inflate and it's not in your way. ..........
I have a friend who bought a small Zociac roll up and a Honda 2HP 4 stroke motor. He loves it.
In similar boats we used a small light weight dinghy. Probably one of the best--especially for pets-- is the Alaska series. They have a "sharks skin" bottom which does better than any fabric I have seen on inflatables on rocks.
We have cruised with dogs for many years and thousands of miles--there is not a real problem with fabric bottomed inflatables--but the hard bottom ones are better. If necessary you can put wooden floor boards (just 1/4" epoxy saturated, with micro beads on the top surface) in the bottom of the boat, if you are worried about the dogs claws. The small boats (6'6") are very light--about 30 lbs and inflate in a couple of minutes. An 8 foot boat is much more suitable for two adults and a couple of dogs.
We have a roll up with a 5 HP motor. I keep the motor in the cabin while under power (I run it until it shuts off to empty the fuel).
We have dogs and their claws have never been a problem.
Sometimes we will keep it inflated and turn it upside down, bow forward, and lay it behind the seat at the helm. Then tie it down with bungies.
I carry an 8 ft soft bottom on my swim deck. The motor has to come off but I just tip it up and tie it off to the cleats on the swim deck and the cleats up top, and it holds just fine. I do not have a huge swim deck to work with, but I can still get on and off it. It does make it difficult if you have to board the boat from the aft.
Tanq,
Shouldn't this read putting a dink on a dink? Come on that is not a boat, it is a tiny toy!
Why carry a toy on the back of a toy? Get a real boat over 30 feet long!
P
Hehehe.....Ya know it's a funny thing.....
I just got home from work and was thinking to myself.....
"Gee....Boatered has been awfully quiet lately and it IS getting colder here in the north and most people up here have their boats out of the water already......Maybe I should Post something really stupid.....or just SAY something really stupid and get some sort of controversy
going"
But it seems you just beat me to it.
It's the same length as a Carver 3207......So maybe their lying about the size of theirs?
Just trying to give you a taste of your own medicine!
Enjoy your winter!
Tanq, looks to me like your only option is to put it on the bow, with the molded in swim platform, it will block access.
Get a lightweight one with a high pressure floor, the floors are pretty heavy duty and should be fine with dog paws.
The problem with deflating it and storing it is that it takes up a lot of room and it's a pain in the butt to have to inflate it all the time.
Get a cover for it, as the UV rays will destroy it, especially if it is PVC
If it doesn't have a motor and is inflatable, just pull it up over the bow rail and strap it to the fore deck. I have a Chaparral 240 Sig and that is what I do.
Looks like that's going to be my only option. I thought that might be the case. Now the thing that'll be
a concern will be the 'lift' that the wind will cause
under it when traveling.
You gotta strap it down good.
I wonder if you can get like the straps that they have for ski racks or when I used to go surfing, surboard racks. The went under the rain gutter lift on the roof and you would tighten them up.
Maybe put them on the rub rail and tighten. Get more leverage with a lower place.
