Dink slow leak
Ehoyles
Considering buying an eight year old Nautica 10.5 hard bottom with a stated 3 day slow leak. My question is; has the life if the fabric worn out to the point that it leaking through the fabric in many places , or just a small pinhole leak. The current owner offered no opinion. The price seems right $450 but....if the fabric is so porous that is does not hold air, then it is probably beyond repair. Opinion please.
Captain Ed,
It likely has a single pin hole or the o-rings on the fill tubes are leaking. Pump up the the dinghy until firm, Get a bucket of soapy water (more soap than when washing the boat) and a sponge. Wipe the dinghy with the soapy water. Leaks will blow bubbles. If the seller will not let you perform this test, I'd walk from the deal.
I have a Zodiac for sale in the classifieds.
Hypalon or PVC?
If PVC and it has been kept in the sun uncovered, it might be in lousy shape.
Hypalon holds up much better in the sun.
If it is just one pinhole leak, there is a sealant that you can put in the deflated tube, inflate the tube and turn the dink over a couple of times to spread it around. It will find the leak and plug it.
unless the fabric looks badly worn they can usually be easily repaired. Why not take it to a repair shop for an estimate then buy or not based on results.
The sun killed my Hypalon. 100 Denier fabric started comeing loose. Leaks everwhere. Patches even came off the cloth.
Better pass. Why take the chance?
If the dink was kept out of the sun it might be worth a look. If not, it might be worth repairing. If it PVC I wouldn't think aboout it.
PVC is hard to get patches to adhere to. the This was a nightmare with PVC Zodiac brand dinks. I cruised for 7 years and saw a lot of deflatible dinks. Many Zodiacs that looked ok, in the trash pile.
with a tight budget like a lot of cruisers, I have had 3 dinks and have put on many patches.
The best 2 part glue I have found was "Rema Tip Top SC2000" The best part is it doesn't have a shelf life, and when I was buying it, it cost lesss than 1/2 of the stuff sold in marine stores, which had a short shelf life.
I have "patched" a slow pin hole leak with a drop of crazy glue.
Large gashes, are the most fun, when you need to put a patch on the inside and outside!!!
My used $100 Avon 10' RIB lasted me 5 years. I think all the glue and patches over those years cost me almost that much!!!
