I check and usually replace the caps and rotors on my 2003 Crusader 5.7L MPI inboards at least once a NE season (~~200 hrs /season) . Maybe twice. On my old same size carbed motors with the excellent Delco Voyager EST Distributor kit upgrades , the caps and rotors would last in great shape for at least several years or longer. But I would still check them.
Plugs (Iridium) I change about every 2 -3 yrs. Since I am checking them to see what they can tell me about the recent combustion quality and they are so difficult to access, it makes sense to go ahead and replace with new, properly gapped plugs rather than reinstall the old ones.
Relays may last the life of the motor, but stuff happens. I haven't had tp replace any relays on the 2003 engines but did have to straighten a slightly bent relay harness connector pin which was causing occasional brief hesitation for 2 yrs until straightened .
If you aren't just kidding, I really hope you have not gone almost 900 hrs on your engines without doing all normal responsible preventative maintenance on them as the owner's manuals prescribe.
