DIY mold control? Suggestions?
ChefJunk
Hello,
I have a 32 Carver Montego that I purchased late in the fall of last year. There were a couple spots of mold here and there that I knew of as well as a smell that needed addressed. This is the result of lack of care by the previous owner (NOT Starry Night, the owner in between us).
I addressed these issues, but am now taking some things apart and getting deeper into the boat and am finding surface mold behind wall panels, under cushions, on the inside of cabinet boxes, and everywhere else. It is not a major problem at its current level, but I am concerned with how to get at the areas I simply can't get to. I have resolved the issues where I can reach, but is there a "bomb" of some type that will get into the crevices?
You may want to rent or purchase an ozone generator. There are also numerous chemical formulations some only take 24 hours, it may take a few chemical treatments. I haven't had a mold issue but perhaps others will give specifics.
Chef: 2 issues with the "stuff" you do not think you can get at - (1) with sufficient moisture (high humidty will do), you can have a recurrence of active growth which, obviously, is not good and (2) musty odor may linger for a long time. My suggestion is to try to get at and treat (use a commercial biocide, not bleach)anything you can. There is no miracle "bomb" that will deal with the problem in hard to reach places. Need to get to them and treat them.
I treat mold with bleach.It kills it 1st time.50/50 mix and then on a rag to wipe down.
Bleach may kill the active, living mold organism, but it does not destroy the spores which will sprout new organisms when the right conditions re-occur. A commercial biocide typically kills the organism and the spores (check the label and make sure it does kill the spores).
Follow Bill's advice and rent an ozone generator. You basically run it for a period of time, like 8-12 hrs, inside the boat and the ozone (O^3) will kill off the mold completely. It will get to everything where air flows so it will get to all of those areas that you can't.
HomeDepot rents them for a four hour period. Pick up at the end of the day and return the next. The solution which is soda ash and two others really works.
the solution is easier than you think, cut down the humidity and the mold will go away. run your a/c unit when you are not on the boat. it will drop the humidity down. you may have to play with the temp setting to get the right mix for your area, but it will work.
as others have noted an ozone generator will kill the live stuff and get rid of the smell, but that is not a long term solution as the ozone will attack metal and remove the plastisizers in vinyl and plastic.
Thanks to everyone for the info.
I have an ozone generator rented for a day. I purchased a good UV/Hepa/Etc. Air purifier for permanent use on the boat. I also purchased some heavy duty surface mold killer that is supposed to stop regrowth where applied.
I think these will mitigate the problem. Thanks much for all the input.
I love this site!
Do I have the solution for you. I have been battling with mold ever since I have owned a boat. My wife is extremely sensitive to mold and is always complaining about her eyes watering and congestion caused by the mold in my 2003 3750 Crusiers. The only solution I have used before is pouring bleach in the bilge works for a little while but it comes back within days (and killsseveral fish in the process) . However, mechanic recommended the Nautic air system. He personally has installed 10-12 of them in all types of boats and every owner has been extremely satisfied.I was reluctant in spending the $1500 dollars on the system but it has worked like magic. The system is essentailly a UV light contained within a box in the air conditioning duct. My wife's allergies disappear within 30 minutes of running the air conditioning. The money was well spent (not hearing the complaining of my wife is priceless. Check it out. It has really worked for me. http://nauticairllc.com/
If you have any questions please don't hesitate to ask. I love it.
Brett
There is a spray call Concrobium which I have used with good success.
Well, here's an update:
I rented a commercial ozone generator and had it in use for 24 hours with the cabin sealed and all hatches/drawers opened. I then spent the day Saturday and Sunday steam cleaning the carpet, carpet lined headliner areas, etc. I also scrubbed the walls with soft scrub with bleach to get rid of grime and some mold areas. I cleaned the bilge as best I could. When I was all done I sprayed a mold killer/inhibitor on every surface I could get to.
The boat has a very nice clean smell now and I am hoping it lasts.
To be safe, I have located a large seven stage air purifier that uses UV and Hepa as well as some other technologies to keep the air clean.
Brett, looks like a great system but I can't swing $1500 at the moment. I will see how this setup works this season and keep that in mind.
Thanks again for everyone's advice!
I read an article about Ozone generators over the weekend and do not remember the source.
Essentially it said to NOT use one in a boat becuase they kill the rubber in any seals etc.
Any thoughts on this assertion?
I asked the same question. That is true for long term usage (like in a lobby) that it will eat rubber and adhesives. 24 hours was not a concern though from what I was told. They are used very commonly by auto detailers and dealers to remove odors from cars.
