DIY Projects while my port engine is out.
jmicklov
Had to remove the port engine to get to the stuffing box, which had to be replaced rather than repacked. The threads were actually loose.
Been trying to take advantage of all that room down there to do some projects that might otherwise be almost impossible.
Plan is to check V drive transmissions on both engines for leaks and fluid levels. Have also completely cleaned the engine compartment & bilge, cleaned out the 'weep holes' between the struts, rerouted cockpit sink drain from going into the holding tank (on port side) to overboard drain, installed a new multistage battery charging unit, checked halon dispenser (it's ok). Just did the impellers on the removed engine last season. I noticed that the sea-cock for the macerator discharge was a bit tight to move, but not sure if anything can be done to loosen up the movement between open & closed.
Any other ideas on what to do/check while I have all that room down there?
Install LED rope lights around the perimeter engine room ceiling ? Go down there and take a nap while thinking of other projects.
if you genny is usually cramped now is the time to access and service it.
Otherwise, when I pulled my engine, I cleaned everything thoroughly and laid down a fresh coat of bilgecoat gray... which does wonders for really dressing up your engine compartment.
--Rick
You still have one good engine don't you? Go fishing.
Soundproof the bilge. I don't know about your 330. Mine is loud at cruise with the factory insulation.
David,
Good point. Mine is pretty loud too, but over the years, you just kind of accept it.
engine room lights!
Install a sheet of polished stainless steel under the engines. Acts as a mirror to spot leaks and 'see' underside of engines. Drips and such just wipe off.
Wow, what a great idea. Are those sheets flexible enough to conform to a rounded hull? This puppy has the 'tunnel' hull.
there's a real lack of pics in this thread....let's see some befores and afters!
