So I have a "new" Merc 496 Mag engine...that is closed cooling. It still has the raw "fresh" water intake of course to run through the heat exchanger to remove the heat from the AntiFreeze that runs through the block.
It has the "pressure" system where you pump air into the system and then all the "valves" release all the water out of the engine.
So basically I am told by local mechanics there is no longer a need to run antifreeze through system. Still have to EFI Fog, etc...but skip the antifreeze part.
Does anyone have any real world input? Could this be true?
