I need to tie up in a slip and not use the cleats on the dock. Need recommendation for the right knot. I will be using spliced loop end for cleat on my boat. Need to tie bitter end around a tire which is in turn connected to the dock cleat via chain. This is the recommended setup at Pier 39 due to large surge.
Should I use "Figure Eight" or "Buntline Hitch" or ?
