Dock Line Tension Question
David M
Some of my 1/2" triple strand nylon dock lines came unglued in the washer last week. I have a roll of 1/2" braided nylon in the garage and desire to make permanent dock lines to leave at my home slip for the season. In that these will not be adjustable (or is that a bad idea) how tight should the boat be against the fenders. The marina itself is very protected. The docks are floaters and my slip is the closest to land protected on three sides by berms and is about 300 feet from the river. My only headache and concern is people power loading their boats onto their trailers.
Any and all comments welcome.
TIA.
Two questions about how you dock, you said the docks float, do you tie up tight to the dock, on one side, also how large are your fenders?
Next when you say permanent dock lines, are you looking to eyes on both ends? I would make them the same lenght that you have now. If you want to leave them on the dock, I would put the eye one the cleat on the boat and then tie the dock lines to the cleats on the dock, when you go to leave, just slip the eye of the boat cleats, and your off, when you come back you do not have to adjust your lines at all, but if you do need to at some point in the season, you can.
I would not put an eye on the dock side. The lines will stretch after a week or so. You will need to tighten them.
IF your marina is calm, don't make it too tight that the fenders are always rubbing against the dock and the boat. Not good for either. Let the boat come to rest where the fenders hang from the boat and do not touch the boat or the dock.
I have always permanently fixed lines and fenders (usually 4) to the dock... Make life easy when coming and going.
I too keep permanent dock lines and fenders at my slip. When leaving the boat, I center the boat in the slip and have the dock lines long enough to allow no tension on the lines, but short enough to not rub against fenders and/or docks.
When I am at the boat, I remove the starboard dock lines from the boat and snug up the port lines so the boat rests against the floating dock. This makes it much easier for me to board and load my boat. Being short, I cannot step a 9-12 inches to reach the swim platform and I do NOT want to fall into the drink!
My slip does not have cleats. Instead it has 4 x 4s which support the roof of the shed. I tie off the bitter end of the lines onto those. And I have cup hooks on each support which holds the eye of each line when I untie my boat. Keeps everything off of the dock and nice and tidy.
We have fixed lines at the dock and carry a full set on board when we are cruising - just makes it easier and quicker to tie up.
We have a lot of movement on our docks and over 5 years of being there I have learnt that it is best to let the boat float free with only the spring lines tight. This avoide constant rubbing of the fenders on the hull (caused a dull spot on our first boat after a year) and also minimizes stress on the boat and dock cleats. Our lines are adjusted so the boat can float about 2 feet away but the spring lines are tight and will naturally pull the boat closer. All other lines are adjusted so they will take strain at the same time.
It took time to watch the boat's reaction to a wake coming in, current, wind etc and find the proper procedure and method of tying the lines to keep the boat secure and minimize damage to the boat while she's tied up.
Yes, the boat is only secured to the floater, port side to.
10"x26". However, I had one split and substituted a 6"x15" I had laying around to keep the stern from hitting the dock. It worked OK and was nice to have the boat's entry point 4" closer to the dock.
That was what I was thinking. I do not know how to back braid period; let alone double braid line! I was going to loop one end through the center hole of the cleat and attach it with some SS line clamps and heat shrink tape. That would at least partially preclude the any theft issue. I was goint to do the same thing on the other end, only a larger loop to put on the boat. The length would be fixed.
I never thought that part through.
Thanks.
Braided nylon stretches? I did not know that.
If you might have problems with splicing a loop in double braid line try using a bowline at each end. Simple and has the same effect as a spliced loop but still maintains adjustability in the future if the line stretches. A bowline will only take about 30 seconds to tie compared with a lot more time for the splice.
That's how I had been doing it and it seemed to work well. I didn't know if it was correct or not. Some folks there have so much slack their boats look like a broom stick in a bucket in the slip. I know that is too much. In my Navy days, the ship may as well have been welded to the pier. the lines were that tight. In that these would be permenant, I did not know where the happy medium was.
No, double braid nylon will shrink up a bit after a season in the sun - at least the cover will, making the line 'harder'. The poster above that mentioned leaving the shoreward end of the line made to a cleat instead of eye spliced was dead on. Also, Samson (gold standard for splice data) advises against forming a sling (the term for a short line with an eye splice on each end) on lines less than a certain length (generally at least ten fid lengths, as you'll need 5 between your stopper and your extraction point, "X", when you form the splice.
As far as tension - I'd go with the above "fenders not touching boat or dock". Double braid is very elastic.
The boat is in a covered slip all year on a river and behind a tule berm. I tie up with four lines to two dock cleats at the bow and around two posts at the transom corners. The line is three-strand nylon. I place the boat in the middle of the slip and snug it up with no slack. The line and knots stretch enough slacken a little in a few hours. I usually never have to re-tighten before going out again. I don't use fenders at the slip. This system worked during a couple of days with sustained 45MPH winds last winter.
When my boat was new, I had it tied in my slip without any fenders. One of the dock rings came out and the boat rubbed against the dock all week. Naturally there was a nail protruding which rubbed all the way through the gelcoat. It cost me $145 to have it repaired. Fenders are cheaper!
I haven't used fenders at the slip for eight years. Even with fabric covers on the fenders, they rest against the white enamel paint and scuff it in no time. On this wooden boat you don't have the tupperware rim and big rubrail on the hull to deak seam that goes all the way down the sides. That keeps fenders off of the hull.
I have a couple of those big red bumper balls hanging from my dock just in case a line breaks during a storm. They are also good for the days your aim is not as good.
yzer, you bring up a good point. My fenders are hung from the dock, not the boat, and would only touch the boat if a dock line failed. As it is set up, the fenders never touch the boat as long as the boat is centered in the slip.
I was tought gifferent. I just love how some have real long dock lines and put the eye splice on the boat side and lay 40 feet of rope on the dock. Some try to be fancy and do a flemish coil and it looks like a 4 foot round rug. I loop to the dock and keep the extra on the boat. That way if I have to adjust the lines, I do it from the boat. It keeps the dock clean and reduces trip hazzards. With all the chairs, fishing poles and boat hook, Oh, and a crab pot and fuel cans and loose fenders..... WATE..... thats all my stuff!!! I better pick it up before the grand kids fall in.
