Docking a single sterndrive
ok, so once again, don't make broad statements about having more control stern to the wind. It is misleading... i'd hate to be downwind from a guy trying to dock even a 35 express stern to the wind... maybe it works on a small outboard powered boat, but it's a receipe for disaster with anything larger...
My suggestion was tailored to 89SeaRay220. That being said, the same advice is NOT a recipe for disaster for a competent helmsman of a 35' express. About that, we will just have to agree to disagree.
easy guys... variations due conditions is a given !!
Dan said he is trying to get some basic help in calm conditions with an almost empty marina.
My bet would be that both you guys would do better job docking on your boat then on the others.
No problem here. Far as I can tell, the other guy's main gripe is that I didn't say "usually" in an earlier post ("Actually, lying stern-to-wind gives more control.")
Mea culpa. (That's "my bad" to young'n's.)
Bottom line: SPR and I agree on the bow-to-wind, stern-to-wind issue. If others don't, so be it.
The risk of docking with the bow into the wind or current is the force of either of those working their way between the pier and the boat (especially current). If your bow gets forced down at all away from the pier, you're going to be making another approach. This is especially true with boats that have shallow drafts at the bow, with a big sail area - they just take off.
When making way astern, the pivot point on most (not all) vessels moves way aft and this is actually more apparent on larger craft than on smaller ones. By coming stern-in to the wind or current, the length of the vessel which is forward of the pivot point (which is most of the hull now), acts like a wind-vane and will attempt to straighten itself out. You must take into account the available room in front of your vessel to make sure the bow doesn't start coming in too soon. The shape of the hull and your underwater profile will also effect this. You do have more control of the stern than you might think when running astern and quick bursts of ahead power with the rudder(s) already set to whichever way you want the thrust to go, can and will allow you to move the stern with substantial control. Large ships routinely dock like this when the current or wind is pushing them by overshooting the pier a little bit and then slowly backing into and towards it, letting the bow settle in as the current/wind pushes down its side. Normally, they are forced to do this beacuse there is no room to turn around, or the ship must dock on that side for cargo/pier considerations, but it goes to show that maneuvering/docking with the stern into the wind or current is not all that difficult or a definite "no-no" practice.
Most techniques work at nearly all times because unless you're talking about very small or underpowerd craft, the effect of the elements may not always be so prominent. Of course, 10 knots of wind is not always going to have a huge effect on a vessel (even a relatively small one), but 25-30 knots certainly will and a good skipper will know how to use the elements to his advantage.
That being said, boat handling (like many other things) is both art and science. There is no 100% way that is going to work 100% of the time. Different vessels behave different ways in varying conditions and it is up to the discretion of the skipper and what he feels is best and what he is most comfortable doing - that's seamanship. There is no true right or true wrong here. I certainly didn't mean to discredit anyone here - only show that docking with the stern into the wind or current is not a taboo and is done regularly.
you know, docking a boat isn't rocket science... i agree you can do it in variety of ways but using the current or wind is easier than fighting it.
if the wind blows along the dock, by coming in at an angle, bow first, into the wind, you cna use the wind to get the bow and the rest of the boat against the dock with little effort, while using your engines in gear and have effective rudders. doesn't get easier than that.
it the wind is blowing at angle FROM the dock, let say an E-W dock and the wind is blowing from 120deg, heading into the wind is again much easier than having the wind blow your bow away... once the bow is close, throw a spring around a cleat and bring the stern in. guaranteed to work every time.
if the wind is blowing at an angle onto the dock, say from 60 deg, again it will naturally bring the bow and the rest of the boat alongside with little effort.
this has worked for me for the past 20+ years in single stern drives, mid size inboard express and now with the hatt... i've never needed a crew, even in 25kts +
i'm sure i could do it stern into the wind, but i still feel that it is easier facing the wind, especially for someone with less experience.
Personally I don't see too much of a problem... if the wind is blowing along the dock, and I am stern to the wind; I'll put the stern in first, get a stern line out (not a spring) and the wind will lay the bow alongside for me. If it doesn't (wind is off the dock) I can force it in by going ahead with the engine. If the stern is to the wind trying to put the bow in first would probably be an exercise in futility, and vice versa. I'll put the UPWIND end in first, whichever end it may be.
In all honesty; one doesn't always have a choice whether bow or stern to wind. One has to learn to deal with the conditions at the time; there may not be room to turn around.
Arguing about "which is best" is foolishness, one needs to know both.
I think sometime when I am facing wind against the stern conditions, I'll try the stern-in as described. Previously, I've only done that when I was docking stern-in to save dock space.
Arguing about "what is best" is foolishness
Finally, best statement made on this entire subject.
89Searay.....you're on the right track....practice, try some different things you have read hear and find out what works best for you.
With a single inboard, like a Freedom (presumably with a r/h prop), port-side-to is straightforward; starboard-side-to requires a more-involved (but not complex) technique.
baothandler, I agree. BTW my Freedom is a stern drive or I/O, not an inboard.
Wow, I don't know that one. Is it like a sail drive, with the motor mounted in a well? Can the prop be turned to aim in different directions?
Indeed. We tend to do best what we do the most.
hmmm... yeah... sterndrive... inboard engine... outdrive off the transom which indeed can be turned !!
they've been around for... hmmm... 40 years ?
"My bet would be that both you guys would do better job docking on your boat then on the others."
That's probably true in most everyone's case. An exception might be MY boat; it's such a pig around the dock that just about anyone elses boat would be easier.
Methinks Boathandler is thinking of the wrong "Freedom"
No Matter What!!!!
Approach no object at a speed greater than that at which you wish to ram that object.
[/quote]
I agree. It has been said that there is no such thing as a stupid question. My query calls that assertion into serious doubt.
As to your "rocket science" comment:
Though boat handling is not rocket science, they both fall in the same discipline, that of applied physics; they just occupy different locations in that discipline. Applied physics is much more science than art. Mother nature cuts no slack…in the ionosphere, or on the water.
Rocket science is not common sense. Neither is boat handling; otherwise, few if any people would feel the need to spend the money to hire me or any of my colleagues to teach them how to do it.
Indeed, some aspects of close-quarters boat handling are counter-intuitive to many people (like how to use the wheel to control the bow when stopping a stern-drive boat). Some people leave boating because they never got the hang of boat-handling skills; they never got good enough at the physics of close-quarters boat control to allow them to enjoy the boating lifestyle.
I believe that you want to grow the boating lifestyle. So do I.
I am done with you on this thread. Yours will be the last word.
I bet when summer comes, we wont be having these 'discussions', we be too busy BOATING!!!
[:-bouncy]
BRING ON the sun!!
[:-bouncy]
BRING ON the sun!!
YOU'll be boating; I'll be growing boating by teaching people how to boat. By the way…BRING ON THE SUN.
