- Dec 15, 2005
- 19763
- 181
I have a 2001 SeaLand vacuflush system with a couple of issues.
The vacuum pump cycles about 80 times before shutting off. This happens on both heads. I do not know when or if these have ever been serviced. Any suggestions?
The other problem (and critical at this time) is after using the dockside pump out I noticed the tank collapsing while I was in the engine room watching the tank during the process. It collapsed so bad that it pulled the outlet fitting out of the plastic threads in the tank causing a hugh vent leak and bad odor every time it's flushed. After I repair the damage how can I prevent this from happening again when I pump out?
Thanks in advance.
Thanks in advance.
