Dodge V-10 experiences?
glenncal1
Anyone have any experience with the Dodge v-10 engine from the mid 1990's, looking a truck with one. What MPG did you get etc? Thanks
Dave, I disagree. It might be a boat towing issue. Give him a chance.
Buzz
Buzz, Point taken.
Glencal1, Is this about a tow vehicle?
YMMV, depending on how you drive...
about 12-14 on the highway, not pulling
about 8-10 pulling 15,000 pounds
plenty of torque, decent transmissions, thirsty though...
If you are talking about an SRT10 I know someone that has one, the Viper version. I'll give him a call if that is the correct V10.
The SRT10 is a totally different breed altogether. The SRT10 has the Viper Engine it.
I'd rather have a diesel than a v10 on that truck if the gas mileage is what you are after, 10-12 is an average unloaded on highway, 8-10 towing 6000 lbs of trailer. Plenty of power but very very thristy.
Looking for a tow vehicle for a boat and trailer about 8,500lbs
Especially a diesel in CO. High altitudes, the turbo diesel is a great tow unit.
I have a 1998 Ford V10 and it towed 27x10 Carver decently, not great down low withe the DOHC heads but once spinning it was fine. I guess the rig was 10-11k# gassed up and about another 6500 for the van. I'd guess the newer Dodge would have even more guts.
That MoPar V10 didn't get the run or the following the Ford has. Dodge seemed to think they could get by with the "new hemi" - not!
I remember somebody on this forum who had the Dodge V10 in a truck and a lot of expensive down time with it.
The diesel in the Ford is starting to look like a bit of a problem child. The Cummins in the Dodge is the pick of the litter in pickup diesels. My second choice would be the GM Duramax.
Ford's the only one giving you the choice of diesel power or about the same power with gas. In both Dodge and GM the gas V8s are too small, now that GM is getting away from their 8.1 V8.
GM Duramax all the way. The Cummins is nice, but the rest of the truck is plastic, creaky, ....well, just not good.
They're really all pretty good, but all have faults (I'm especially talking diesels, skip the v-10 all the way), it's all up to your tastes.
Had a friend with the Dodge v-10 and he just couldn't say enough bad things about it. Gas mileage, sound, performance, expense, and capacity for towing vs. a diesel.
I be lookin' for a diesel van. Seems Dodge/Cummins is the pick but there just aren't any available. The Ford 7.3 diesel turbo looks to be the most available and best bang for the buck. I'm pulling just under 10,000 lbs.
Charlie, you ought to drive a GM van with the 6.0 liter gas engine and the 4.10 rear, as well as the Ford diesel. The 6 liter is the standard engine in the 3500 series vans since '03, I think. It is rated to tow 10K#, will be cheaper new or used than the Ford and I think you will be surprised how capable it is. Not sure, but the newer ones have six speed Allison tranny's if they are like the pickup. My son has a Ford with the 7.3 Powerstroke in it and while it does pull like a horse, I wouldn't want to live with that noisy beast and I know it won't outrun my '06 Chevy PU with the 6 liter (no contest there)and I am not convinced that it will outpull it.
I pull a Regal 2765 using a 1999 F250 4x4, automatic with V10. Boat and trailer approx. 10,000 lbs. Mine has 3:73 rear end and I get 9 miles per gal when towing. Truck does really good on flats and rolling hills. With different gears it would pull better on steeper hills but the mpg would suffer. The newer Ford V10s have more HP and most likely pull stronger. I would recommend gas over diesel for occasional use. The maintenance on diesels is expensive compared to gas. www.ford-trucks.com is a good site to get info on the Ford V10 and diesel trucks. This site will provide you with alot of good info to help in your decision. Before I bought mine I looked for a Dodge with V10 without luck. I have been pleased with the Ford.
The new Ford diesels are having problems, but the old 7.3 Powerstroke is by far the most reliable of the Ford diesels. I have 96K on mine with zero, no problems. I just put fuel and oil in it. I have pulled up psalzer's 28 foot flybridge on triple axles as well as my SeaRay 270DA. Truck gets up and walks away with both loads.
Steve, I think your 99 has 300hp, mine is 265. and my van is a 1 ton e350 but your 4wd must be a stump puller.
I'm only getting about 11-12mpg empty but it weighs 6009#(20' long also).
Surprise,
I have an old(84) 1 ton GMC van with the 350(gas) and 400 tranny/4.10 rear end. It's happy driving 45 MPH and I get less than 6 MPG when towing.
Just gotta get something better on mileage and can pull the long hills.
Anybody know how the mileage is on a Quigley 4X4/Ford powerstroke VAN?
Charlie, like I say, you need to drive the truck. Vortec technology no doubt helps, but the 6 liter engine seems like it has a lot more power than the extra 3/10 of a liter over the 5.7. I have the electronically controlled 4 speed with tow/haul mode, it pulls a 8K# boat/trailer rig up long hills at 65 mph. It gets 10 mpg with that tow if road conditions let you get up to 65 so that it is towing in overdrive, at 55 it is more like 8 mpg towing. My son's 2001 Ford with the powerstroke and 3.73 rear has a utility body and weighs more than my '06 Chevy, so he gets 14 mpg not towing, I get about 13 not towing using the truck as a work truck, it will get 15 or a little better not towing on the interstate. My son hasn't used his truck for any long distance towing, so I don't know what mpg it gets in that use. I do think you can rest assured that the newer GM gas truck would do better than what you have on gas mileage towing 10K#. I wouldn't want a diesel tow truck unless I towed more than 10K#(although I love 'em in a boat)and even then I wouldn't get one unless I towed a lot of miles or I couldn't get the tow rating I needed with a gasser.
