Drain Dingy Tank
fountain27
I have some small particles that keep cloging my dingy motor's carburator. I would like to drain the tank completelty to remove the junnk.
What is the safest way to pump the tank dry?
I tried to empty the tank by just turning it over, but particles begin to stick to the walls fo the tank and will re-mix once gas is put back into the tank.
Fountain-you may want to turn tank upside down and spray carb cleaner into the tank to flush it out. If the tank is metal and starting to deteriorate trash it and get a new one.
if you can remove the tank, put some cleaner in as others have suggested and add a few marbles or s/s ball bearings and shake it up to loosen any material that is clinging to the bottom/sides. once its removed you can use soapy water to clean it out. just rinse it with alchohol when you are finished and blow out with compressed air to remove any water.
Sounds like no filtration from the fuel distribution point. HUGE problem at my last marina.
First, strain the fuel through several layers of cheese cloth for future use in the lawn mower. It doesnt go back in the dinghy. It's much easier to walk to the house from the back yard going uphill than it is to row in from where ever against the tide.
Then you can do one of three things.
1. Remove any salvageable hardware to keep as spares then shred it with a box cutter and throw it in the trash and buy a new one for about 25 bucks.
2. Wash it with Dawn detergent and a gallon or so of water. Shake vigouously. Rinse repeatedly. Let it air dry.
3. See #1.
