Draining a gas tank
jjones
I supposedly sold my 26' center console with twin 225 Johnsons. I have a deposit in hand and the shipper is supposed to pick it up in the next week or so.
Oddly enough the boat is being shipped to Germany with a final destination of Denmark. Go figure...
Anyway, I was asked if I would try to drain the gas tank. It holds 210 gallons and I didn't top it off as usual last trip out. But it likely will have over a 100 gallons in it. I can safely handle the fuel. I'm just wondering if it's possible to siphon it out through the fill which is located at the top of the side of the hull. Or is there an easier way. I want to try to reuse the fuel so keeping it clean is important.
Anyone dealt with this before?
I'm thinking I'll just drop a long piece of flexible PE tubing down into the tank from the fill and siphon it out best I can. I'm not going to worry about getting every last drop out.
Do you have electric fuel pumps? If so, you should be able to disconnect the supply line from each of your motors and use the electric fuel pump to extract fuel from the tank(s). Just make sure you give the pump(s) a break every few minutes so they don't overheat and run your bilge blower so you don't trap fumes. If you have the squeeze bulbs, you can still empty the tank(s) manually, but it will take a considerable amount of time (and sore hands after a while) as you'll be repeatedly squeezing the bulbs. OR...you can try fabricating into the system, a drill operated "transfer" pump. This will work well also as you can direct the fuel right from the boat to the vehicle or storage container of your choice. Just make sure that your bilge blower is on so any collecting fumes won't build up and cause a potential fire hazard. Good luck to you.
chris
Hey Chris,
I have the squeeze bulbs. But you have given me an idea. It seems like I could take the line loose and use the bulbs to create a siphon maybe by connecting a longer line to drop down out of the boat. I'll have to look and see. Thanks. You may have come up with a good idea there.
I don't have bilge blowers since I have outboards but I may keep some compartments open to keep things aired out.
I might pick up an inexpensive inline 12v fuel pump to do the job.
Glad you liked my ideas (smile). Nice to know I can help out. I have a 19' Starcraft Bowrider with an onboard 24 gallon plastic tank. This boat sat in a boatyard for a year or so and I wasn't sure if the tank even had fuel in it. It did, so I used the integral bulb at the transom to manually drain the old fuel/oil mixture and I refilled the tank with fresh 50:1 mix for my outboard. So far so good, the motor runs strong and if there was any remaining "rancid" fuel in there, it's mixed well with the fresh stuff. I had success with the idea I gave you. No reason you can't have the same. Glad to help!!
Chris
In my stupid days I used a drill pump to transfer gas and got away with it; but considering the arcing inside most electric drills I don't think it's a good idea. The inline fuel pump would be a lot safer.
jj,
From practical experience, you'll probably pass out before you can suck the gas high enuff to siphon it.
I had to empty about 60 gal from my tank. I ended up using a hand type plunger pump to start the siphoning at the end of a long 3/8" ID plastic hose. The 3/8" ID made it easier to pull the gas over the gunnels. Once started the siphon worked like it's supposed to.
I used a 12V auto fuel pump. Attached 15' of gas line to the exit side of the on board fuel filters and ran it outside of the boat.To this attached squeeze bulb and the the pump, used some 10' leads to power the pump with a spare batt.(outside the boat also). Need to use the bulb to prim the pump. I pumped rb2@gr5t 160 gals this way.
Thanks for the ideas. I'll be working on it this evening when the heat of the day dies down a bit.
Once they pick up this boat I'll have to begin the process of finding the next boat. Everyone in my mob wants a comfy cruiser. Seems the fishing boat was too hard on their behinds.
