To change a drive plate that is bolted to the flywheel you need to remove the trans from the bell housing. The input shaft is about 1 3/4 -2 inches long
So , remove positive battery cable, starter, unbolt shaft coupling. raise rear of engine and block .support trans with hoist, remove rear motor mount ears
remove 8 bolts(?), slide trans out of damper. Remove bell housing, remove drive plate(damper)
