Dumb Question about WOT
concorde mike
I've always said it and know what it is but do not know what it is an acronym for. Anybody?
which is real silly on diesels since they dont' have throtles !
What am I supposed to be calling it? Sticks?
diesel dont' have throttles, RPM is controled by fuel not by air.
gas engines have throttles, whether in a carb or in a throttle body in FI engines since with a gas engine you control the air flow and the carb/FI system controls the fuel.
if diesels dont' have throttle valves, they can't have throttle levers, can they?
i guess the correct word for those "sticks" would be power lever... :-)
Air throttle vs fuel throttle but still a throttle!
See what I mean, I don't know what to call them damn things yet. I'm not going to sound very cool saying "If that guy doesn't change course soon I'm going to have to goose the "power adjusting levers"".
No way.
"Goose the throttles, quick" That's much better.
accelerator pedal...no wait...that's cars. Accelerator levers! WOAL = wide open accelrator levers
of course, we probably all call them "throttles"...
rommer... big difference, there is no such thing as a fuel throttle. on a diesel fuel is controled by a governor. gas engine... you adjust air, diesel you adjust fuel.
Right you are Pascal, thats why it is called a fuel throttle system instead of an air throttle system.
Here are a few quotes from Peter Compton's "Troubleshooting Marine Diesels".
"Throttle Controls
Engine idle and maximum rpm are set by the stops on the governor or injector pump. The throttle lever must allow unrestricted....
To check the throttle controls, disconnect the end fitting from the throttle arm on the engine..."
Similar language is in my Yanmar service manual.
from MIriam webster dict. on throttle transitive verb
1 a (1): to compress the throat of : choke (2): to kill by such action b: to prevent or check expression or activity of : suppress <policies that throttle creativity>
2 a: to decrease the flow of (as steam or fuel to an engine) by a valve b: to regulate and especially to reduce the speed of (as an engine) by such means c: to vary the thrust of (a rocket engine) during flight
intransitive verb
: to throttle something (as an engine) —usually used with back or down<the pilot throttled back>
So, technically, to throttle means to choke which implies choking air, one would not choke a liquid. So a throttle chokes off air to a greater or lesser degree which only makes sense in a gasoline engine.
How does Pascal know this stuff!?
Harlen read the definition again. I believe when you close a valve this is choking the liquid. Throttle is a verb. "to throttle or not to throttle".When you throttle you are actually closing off a passage.
ok...so... I'm going to close the throttle on the water line when my water tanks are full.
right...
The space shuttle's main engines have a throttle. The last words heard from the ground by the crew of the "Challenger" were "Ok, for throttle up".
