Does yours read the same 58.4 ft if the T/D is disconnected? Have you tried disconnecting & reconnecting the T/D plug several times to see if it's just a dirty or loose connection? Have you checked the transducer to see if it was kicked up, fouled, bottoming damaged, missing or cable cut or crimped? Does only the digital depth remain the same but the F/F screen still scroll and show bottom changing with charted depth and fish targets? Or is everything locked up on a frozen screen?
If bought a year ago, it should still be covered under the 2 yr warranty though that may or may not not cover the T/D. In general, Lowrance/Eagle is pretty generous with their warranty replacements. If you get an RA return authorization # they may just shoot you out a new one in trade. Give them a call: " you can reach us at our toll-free Customer Service line at 1-800-324-1354. Technicians and representatives are available to help you Monday through Friday from 8 a.m. to 5 p.m. CST, except holidays." Especially on Mondays or Fridays there may be a bit of an "on-hold" wait to speak to a tech.
