Easier boat loading on trailer?
dav
I know a lot of you have boats that are not trailered, but I have a question. I have a approximately 3000lb ski boat that is a bear to load onto the trailer. Once on the trailer it sits fine, I think it has a little to due with the ramp we use. Are the products I see advertised in magazines (bunk pads and spray applications) safe to use and has anyone used them with success?
I'd vore for the sprays.
But, have you considered an electric winch powered by the tow vehicle. You may also find a winch with greater mechainical advantage would be sufficient. There are some good two speed winches out there.
Or, it could be as simple as backing farther into the water or extending the length of the trailer tongue.
What type of trailer do you have? Does it have mostly carpeted bunk rails or more rollers? What difficulty are you having when loading?
If it's carpeted bunks just soak them down with a can of silicone spray each season. My 18 footer was a bear to get on and off the bunks until someone told me about this trick. After that it just slid on and off.
I trailer a 6000 Lb boat on a bunk trailer with a manual winch. I did have teflon coated slicks installed on the bunks to make it easier, but as long as I back far enough in it goes on fine. Look into having the slicks put on the bunks, 3000 lb. should slide fine.
MJK
When you back down to retrieve, over-dip the trailer (so all the bunks are soaked) and then pull out to the right point. This will help the boat slide on the bunks better.
Usually water up to or close to the top of the trailer wheel wells is a good starting point.
Try that and then adjust according to your trailer and boat combo.
I trailer a Chap 290 (loaded around 10500lbs) I always back down where my two main bunks are well under water. Just the two small bunks up front that catch the deep vee are close to the water line. When I pull out of the water the two upright poles help keep the boat lined up on the trailer. Also the top of the upright steel poles that have pvc pipe on them used to rub and leave marks on the side of the boat. I put a 2 inch roller on top of the pvc caps and that stoped the marks.
Both of my boats have had double axle trailers. I usually back down until the very top of the fender is two or three inches above the water. I have never used the pole guides or anything other than a plain trailer. I can put the boat right on there, even at 2AM.
kjw has a great point that if you wet the bunks, it will make it slide on (and off) easier. I have un-winched my boat before backing down the ramp. I would use extreme caution if you are doing this and make sure that you know your boat, trailer and ramp before doing this. You also have to be careful as to not stop quickly. Keep in mind too that if your bunks are wet or if use use the silicon spray, your boat will come off the rails more easily...as in if you don't properly winch it, etc.
Thanks for all of the suggestions. My biggest problem is if I back too far into the water, the bow will not go over the bow rest. The trailer is a trailmaster with two carpeted bunks. I think I will try the silicone first.
dav
A good rule of thumb is to back in so that half of the bunks are in the water. This gives you enough bunks to catch and center the boat and still be able to catch your front stop. Silicon spray works fine, sometimes too fine.
If you use spray or "slicks" be sure and leave the winch strap attatached until the trailer is in the water and the boat can float. Plus, be sure and have a chain on the bow, from the trailer frame to the bow eye. I have slicks on the foreward 8 feet of my Cat trailer and it makes the world of difference in loading--but it will come off very easily!
The Liquid Rollers silicone spray is excellent--but use the same precautions.
When I load my wakeboard boat on a steep ramp I have the same problem with respect to the bow being in the right position. To get the boat to load properly I don't back the trailer in so far, leaving the front bunks high enough to lift the boat to position the bow properly.
I will bring the boat up to the trailer, position it gently, get the bow into the bunks then apply just a little bit of power to push the boat up on the bunks. A little assist with the winch can help out as well.
Rod
Wow!
I used silicone spray on the forward half of my bunks, what a difference. You guys weren't kidding when you said to make sure bow strap is secure.
