educate me on props please
justgotaboat
We recently repowered our 2001 245 sea ray weekender Bravo III with a 383 stroker engine. It previously had a 305 MPI. It is recommended that we get a new set of props to help match the power upgrade, which makes sense. The mechanic said he had a set of used props that he would put on there to see if we like the way it ran with them. I don't think this guy is just trying to clean out his shop and get rid of an old set of props, however I am going strictly on what he says, so I turn to you guys to help educate me more on props and what size is needed.
We had a set of stainless steel props on there, to which I cannot off hand remember their size and pitch, however i am 99% sure they were the size and pitch that came stock on the boat. The props the mechanic gave us are both stamped "Mercury Marine" and are stainless steel as well. They are clearly used with some corrosion and minor knicks (and he told us they were. He is urging us to buy them if interested, but to use them to try it out none the less).
The outer of the two props is stamped "Bravo III" and "48 - 823666 24P". The inner of the props is stamped "48 - 823665 24P" however it is not stamped Bravo III.
First, what do these numbers mean? are I would assume that 823665 and 823666 are serial numbers. Is that correct? I would assume the 24 is the pitch. Is that correct? What does the 48 stand for? They also appear to be etched or lightly stamped with with WB 1163 (on the 823665) and WB 1162 (on the 823666). Any idea what these numbers are? (and note that they are in reverse sequence as one would think)
Is there a reason why one of the two props is stamped Bravo III and the second is not?
Also, The two props appear to be a different size. If you measure the inner prop (the one you put on first) the blade of the prop sticks out about 5 1/2", however the outer of the props measures about 4 3/4". Is this a sign that the props have been damaged and reconditioned? or are the props on a bravo III actually designed be two different sizes?
Is there a rule of thumb, chart, tribal knowledge, to figure out if the props he gave us really are more appropriate for the power of the new engine, or what size props we should put on it? Anyone have a similar set up and can tell me what you have?
Any recommendations for what size and pitch prop we should put on a 245 Sea ray weekender with a new 383 stroker and a bravo III? Any recommendations on brand or anything else to look at in props? Anything else you think I should know or information you find useful?
Thanks for the help. This site is awesome, and definitely wonderfully useful, helpful, and extremely educational. I love it. Thanks again
Bravo III props come in sets, the front one is smaller than the rear - the 24P is the pitch.
fitting test props is common practice and not an attempt to rip you off. You need good, not dinged, props to see how everything works together and adjust from there as needed.
What size are the props that are on the drive now? Need to try these to get a baseline to find what direction if any that you have to go with a pitch change. RPM at WOT will determine pitch needed.
48 - 823666 24P and 48 - 823665 24P are what are currently on the boat and what was recommended by the mechanic who did the repower. He placed these props on before we picked her back up after the repower. We are still in the break-in period for the engine, so we are babying her as recommended by the owners manuals (which recommends not going to wide open throttle until after 20 hours).
So changing prop pitches is more a guess and check than a science?? and it is based on trying to match the wide open throttle you are actually getting and what is recommended as being the wide open throttle by spec??
a little of both but it is cheaper to try available props before special ordering the wrong ones. An experienced prop shop could probably tell you fora standard engine but you have an engine of unknown HP so how would they begin??
