Emegency Battery Pack
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
Hi all,
I have a single battery in my 21' bowrider. As a precaution, I carry one of those jumper packs on board when we go out for the day, as we often will float around in a cove and placy the stereo and I don't want to be stuck with a dead battery.
The problem is, I always have to remember to dig it out of the boat the night before and charge it on the workbench, and then remember to put in back in the boat in the morning.
Here's my idea, and please tell me what you think, safetywise and such:
First of all, I *THINK* the unit will charge off of a DC outlet, but I'm not sure.
What if I were to install a DC outlet in the engine compartment, one that was only on when the engine was running? Then, I could keep the unit plugged into that outlet at all times, and it would catch a charge everytime the engine was running. It usually only takes an hour or so on AC to get a full charge, but I don't know about DC.
*IF* it doesn't charge on DC, what do you all thing of me installing a DC/AC inverter in the engine compartment, again, one that is only on while the engine is running?
If the issues are installing this in the engine compartment, please say so. I *could* investigate using some space under the helm to install the outlet (AC or DC), and then have a nice place to store the unit out of the way. However, that would entail some cutting into the fiberglass under the helm area, and I'm really not sure if there's enough room under there anyway (until I cut into it).
Here's a shot of the helm area that *might* have enough room to store am 18" x 10" x 10" battery pack and outlet:
ANYTHING electrical installed in the engine room of a gas powered boat MUST be ignition protected for your safety.
I think you might be better off plugging the jump pack in at home at end of each weekend as part of your checklist and that way it should remain charged. FWIW I have a jump pack on board that I use to power my diving system and i only charge it every few months after use. It holds a charge for much more than a week if not used.
Why don't you just install a second battery? Use that nice Blue Sea system with the voltage sensative relay. Easy to do.
"jumping" a dead battery while the battery is in the engine compartment is also a bad idea----Sparks=explosion! If you have a dead battery and no marine charger, the battery should be charged out of the ER.
They sell lighter socket adapters with spring clips cheap enough. I have one that I use for my spotlight on occasion. I clip onto lugs up under the helm with it. Honestly the thing's been hanging under there for years and never pops off.
Does something like that work? Or maybe hard wire a socket to your battery terminals and then sneak the wire forward to your under-the-stern-seat storage area, if you happen to have a storage area there as my bow rider does?
On the other hand, is there room on your boat for a second battery an isolator and a switch, so you'll have an extra battery charged at all times, but it won't be used until you decide you need it.
Well, I guess the "right" way to do it would be to add the 2nd battery and an isolator switch, but, as you all know, I'm cheap. I already own the jumper pack (my sister gave it to me for my birthday), and I thought adding a socket and/or fabricating a storage area for it would be cheaper than buying a switch and a new battery.
BTW, I checked the user manual, and it DOES charge via DC, so an inverter would not be needed, just the DC outlet (boatfix.com has them for $2.27: http://www.boatfix.com/catalog/133.pdf). I think I'm gonna start poking around under the port console area, as I have a binocular storage case there that I can remove and cut an exploratory hole. You can imagine the binocular storage case just to the left of the fire extinguisher, but not in the picture above as it wasn't installed at the time of that picture. I could remount the binocular storage case with a hinge that could then double as the compartment door. Hmmmmmmm....
What do you all think of that? It would certainly cost under $10 in materials, and just a couple of hours in labor (same amount of labor to install a second batter and switch).
I would install a second battery with switch as stated. Use only one battery per day/weekend. Since you trailer the boat, I would occasionally put a battery charger on them while at home to ensure they are getting a full charge.
One way to check to see if you can recharge the battery back from DC is to measure the voltage of it's battery prior to recharging. It should be 12.6 volts. Now connect it the boats battey and start the engine. If the battery on the battery pack is reading 13.7-14.5 volts (or close to that) it is charging. About the only way to have it charge only when the boat is running would be to use a relay that is triggered when the key is in the 'On' position.
All the above; however: A decent booster pack will retain it's charge for several months--maybe more. No need to recharge weekly!
Whoa! As I look at the pic of your helm, I'm pretty sure I see a DC plug already installed.
To the right of your wheel, below the group of switches [I guess], is a round black item. Isn't that a cigarette lighter adapter aka DC plug? Just have a male plug running from your charger to the DC plug [female]. If that plug is "hot" when your engine is off, you will be draining your battery more if you leave it plugged in, so you would have to watch out for that or make the plug only operate when the engine is running by wiring the plug to your ignition switch.
Gee, it seems to me adding a second battery would be so much easier and a one-time expense. Join the big boys, Bob ;>)
How many years is a booster pack good for? Is there any way to tell that a booster pack can no longer hold a charge (except for the obvious)?
Hi Liz,
Yes, I do have a DC plug (cigarette light type). However, it is hot when the boat is off, and I don't want a wire hanging out of it all the time.
Steve/Crownline,
According to the manual and my experience, the battery pack hold a charge for 2-3 months, just sitting around on the boat attached to nothing. However, I'm SURE that the time I need it, it will have lost enough juice that it won't be able to start the boat. That's why I want to do this setup as I've proposed. Plus, I can never remember the last time I charged it, so I usually take it out the night before and freshen the charge. About half the time, I forget to reload it back into the boat. GRRRRR....
I don't know why I fret about this so much, I've never had to use it in my 6+ years of boating...
Originally posted by Crownline 242
Bob,
If you are looking for your son, he is hiding under the cover in the bow.
Good eye! However, that is Anna, not Bo. :)
We have a booster pack I got at one of the local boating stores. I have had to use it on several occations! For maximum jump starting ability, I have found it needs to be on charge to be "full"
I keep it in the salon, plugged in to 120v when ever on shore power at our slip, it's always ready to go.
Always follow safe jumping procedures... Open engine access hatch, allow time to ventilate any fumes, run bilge blower 4 minutes, connect jump-pack positive(+) first, then connect jump-pack negitive(-) to metal ground on engine away from battery being "jumped" Never had a problem doing it that way...
can you charge the jumper in your truck on your way to launching?...no idea how long it takes to charge one
Hey Bob........ before you blow your boat up.....why couldn't you place the jumper pack next to your battery......and connect the charger pack to your boat battery...( + & - ).....let your alternator charge both....battery and jumper pack........then when you start your party.... just disconnect the pos(+) of the jumper pack off the battery.......THEN if you need a jump.....after a day of fun......just reconnect the (+) clamp and jump the boat battery ?
Or did I miss something ?
Plugs arc, not for engine bay use.
Battery combiners are sooooooo inexpensive and since those jumper packs are notoriously cheap-o, there is a good chance the one you own is too. The last time I needed mine, it was curled up in the corner of the garage and so dead even the flashlight function would not hardly even light itself up. I had to plug it in for a couple hours to be able to use it.
It really does sound like more of an issue with priorities than cost since you can buy a battery and combiner both for 100 bucks. Certainly you can pay for that by spending just one day tied to the beach floating in tubes instead of pulling them. Buy generic beer. Heck do something to not have to mickey mouse something together! To think of cutting into glass instead of just adding a battery, all to install a cheapo style battery pack that has a high probability of not lasting more than a season or two.
Well....I guess its clear what my opinion is! :)
Hey Don,
Basically, that's what I'd be doing if I installed the $2.27 DC plug, except it would automatically turn off when I stopped the engine. I'm just a little worried about doing all this in the engine compartment.
onthecreek,
I could charge on the way, as I have a 12v plug in the back of the Durango, it would be pretty easy. But, the invovenience of hauling it in and out of the boat (as well as remembering) will still be a problem.
Ghost,
When you put it like that, I guess you're right.
Remember, the biggest thing we have to protect ourselves from is.....Ourselves. The problem with the haul around and plug it in theory's is that they still rely on you doing something, or more importantly, the fact that you will keep to the plan and not move it, touch it and later forget. Unfortunately, that's the most likely problem statement to begin with. That's why the installed systems are such an improvement. You really have to work to defeat them. That doesn't mean we can't/won't find a way to defeat ourselves anyway, but it does up the bar.
Here....play the game with me for a moment. Sit down. Relax. Close your eyes, no wait you won't be able to read. OPEN your eyes....Relax. Ignore the rest of the world. You are drifting deeper and deeper, the world is floating away. You are now on your boat. The kids are happy. the wife is happy. You, my friend, are happy. The water gently laps against the hull as your float in your inner tube, beer cooler within arms reach. The family keeps thanking you for such a great day on the water. There are other boats floating near you and you can't help but notice the admirable glances that keep getting flashed your way. Your living the dream! Breathe in. Breathe out.
Suddenly the radio starts to die. Little Anna says she is getting cold and wants to go in. Bo says he had a great day on the water but wants to get home in time to do some homework. You turn the key and hear that slow growling whir of a slow turning starter. The boats around you are packing up and you catch hints of those sly grins that mean that everyone has noticed that you ran your battery dry. They wave jokingly as they scream out of the anchorage shouting "see ya back at the dock SUCKER". You could quickly wave for help, but not having checked your wonder pack burried out of sight and not having touched it for 6 months, you can't remember if it is even still plugged in. Your pride takes over and lets the other boats leave without so much as a horn honk. You are suddenly finding religeon in ways you have not found in years. As the light starts to fade, quickly, your wife turns to you, says that she is getting a headache and is HUNGRY. She asks coyly, but firmly "Is there a problem Bobby?". Now. Bob. I ask you...... How much would you be willing to pay to have the RIGHT answer for your wife, right at that very moment in time?
Go spend 1/4 of that amount of money and you will have way more security than you will ever need.
This is how I evaluate the value of these kinds of "toys". I sleep better at night for it.
