There have been many discussions about running on one engine in a twin engine set up for fuel savings. Many modern engines, especially diesels, have fuel flow measurement systems now so how about some ROs doing tests to determine the practical result of single engine running.
To develop valid comparison date we need consistent data points so I propose the data be taken at 6,7,8,9 knots. Don't overload your engines trying to hit 8 or 9 if it seems too much for your boat.
The report should show single vs. dual actual metered fuel use for both dual and single operation at those gps measured speeds in zero current and wind. If you cant do zero current try cross current or up and down current average. Boat size and type, and engine details will be needed as well.
So how about it, will the BE boaters provide the data???
