Engine and V drive oil?
rnbenton
I went to help a friend do a lube change on his boat. Older gentleman, older boat, ehgines have about 1700 hours but run very smoothe, start at the touch of the switch and don't burn much oil at all.
Everything went as normal, pumped out all the old oil, changed the filters. But then, I noticed he was going to use SAE-30 Heavy Duty Diesel Engine Oil.I asked him and he said he'd been doing that since the boat was new and used it in both the engines and V drives. I didn't question him further but surely wanted to ask you guys about it. Is this a good thing to do? Why or why not?
The engines are 230HP Mercs. Chevy short blocks. I am almost certain the OEM Manuels do not call for heavy Duty Diesel Engine Oil. :)
Originally posted by Shadowcruzr
Depends on what the OEM manual calls for.
For moderate ambient temps 30W has been the standard default crankcase oil forever for a lot of marine gas engines. My crusaders spec 15W-30 but the factory techs say 30W would be perfectly fine as well, just might be slightly slower starting on colder days( I use the spec'd 15W-40.) The important thing to look for on the oil label is that it lists at least the engine manufacturer's minimum API "S" rating ."S" indicates it is rated for "spark-ignition ( gasoline or LP or propane)engines. Newest gas engines probably spec "SM", the latest API rating, but older gasoline engines that spec ,say, "SF" would also be at least as happy with newer "SM" oil. Some diesel rated oils that have API "C"(for compression ignition) rating on the label will also list an "S" rating keeping it suitable for gas engines as well as long as the "S" second letter at least meets the manufactures min API rating.
I usually use Valvoline All Fleet Plus heavy duty diesel oil that includes the "SL" rating good for my MPI gas engines. Note: While the latest "S"rating "SM"is good for any gas engine , the letter-progression after the "C" for diesel oils does not necesarily apply to diesel engines- they must have the correct API "C + suffix letter" ratings.
http://www.aa1car.com/library/API_ratings.pdf
OK, the stuff my friend is using says API CF-2, CF, CD-II, CD/SJ. On teh donut it says API Service CF-2, CF,SJ on the top half, nothing on the bottom half. SAE-30 in the center. Here in FL cold weather starts are very seldom and issue. :)
Thanks for the info.
I can understand the engines. Several here say they use Rotella in their engines.
BUT....IN THE V-DRIVES!
I was only talking about my V drives. The new 8.1L HO's require different multi viscosity oil. I use synthesized oil in the engines.
Is it by any chance a Walters v-drive? They take SAE 30W according to the Crusader owner's manual. Velvet Drive & Hurth v-drives' recommended fluid is Dexron III.
Drives are Walter RV-26's.But the basis for my question was; Is there anything about oil specified for diesel engines that make it better or worse for a gas engine?
As best I know, the diesel rated oil meets certain specs for the added stress placed upon that type of engine including better suspension of the ash created within the engine. Many engine oils today meet that same specification and are good for either gas or diesel engines. Prior to all the choices available today, 30W HD oil was the only choice, ran it myself in numerous different applications. It was considered better oil in its day, not so sure that is the case now with synthetics so readily available.
I can only relate to my 1985 Honda Prelude. The 5 speed transmission took SAE 30. I wish my current V-Drives were. I would do some serious mods to mate the transmission flow to the engine oil flow.
