Hi all. I need to replace the port engine in my boat. It's a 1997 merc 5.7L 2 barrel with flat tappets, thunderbolt V ignition and it's pre-vortec
I found a drop in that if compression checks out I'd likely buy to replace it. The drop in is a used 1995 MerCruiser 5.7L with 2 barrel carb. Don't know the ignition system yet or the tappet type, but assuming they were a match, is this the same config?...are the parts interchangeable?...example would the heads of the 97 fit the 95 and vice versa?
-Rick
-Rick
