engine mounted trolling motors
eaglegph
Just saw a display for MinnKota 24V and 36V elec trolling motors attached to the lower units of an I/O. We use our 25' Tiara cuddy with a single 228HP mercruiser. Problem when we're trolling on Lake Erie, can't troll under 2.5 mph at minimum idle. Someone suggested some kind of drag sock on a rope. A pro at a recent walleye seminar recommended trolling at 1.0 - 1.2mph. Anyone tried a trolling motor on a 4000 lb boat? How about those plates that drop down just behind the prop?
If this boat is used mostly for fishing I would think about adding a (gas)kicker motor, 9.9 would be plenty. There is a way to tie it into the steering of the I/O. Does the I/O have power steering? Trolling drags and the plates do work but they both have their disadvantages. Even though the kicker is a lot more money I think you would be happier in the long run. I think the trolling motor would be too weak.
Good luck
Niles
I've pushed a 35', 18,000# houseboat at 1 mph with a 24# thrust trolling motor... CALM conditions and just for grins. I see no reason why the motor you mention (80-100# thrust) couldn't handle a 25 footer under smooth conditions. If it gets rough you'll be using the main engine anyway.
Battery capacity might be an issue. Talk to the other fishermen in your area and go with their advice on where/how to mount it.
re Gassers: I pushed that same houseboat at 2 mph with a 4 hp Evinrude.
I think the "drag sock" would be most cost-effective.
Kicker is definetly the way to go. You will go through the battery way too fast trolling continously on an electric trolling motor.
Being out on Lake Erie the kicker is also a good backup to have if you have main engine troubles.
Drag sock is good to, but make sure you get one that is big enough for your boat. They can tend to get in the way landing fish also.
