Engine Problems on USS NEW YORK
saltysam
Engine components on the 2-month-old amphibious transport dock ship USS New York failed during a recent at-sea assessment, forcing the U.S. Navy to keep the ship pierside at Naval Station Norfolk for repairs.
The Navy described the failed equipment as main bearings on the ship's main propulsion diesel engines, a component that holds in place the ship's engines and propulsion gear. The Northrop Grumman-built New York has four main Colt-Pielstick diesel engines; it's unclear how many are affected.
Navy engineers found the problems during a weeklong, post-delivery underway examination of the ship's engines, said Lt. Cmdr. Herbert Josey, a spokesman for Naval Surface Force Atlantic in Norfolk. After the damage was found, the ship returned to Naval Station Norfolk under its own power.
The failed components are under warranty and will be repaired by Northrop and the engine manufacturer, Josey said.
Engineers are now working to determine whether the problems on the New York could also affect other ships in the San Antonio class, which are built at Northrop's Gulf Coast shipyards.
The Navy is also working with the manufacturers to determine the cause of the engine problems, including an examination of maintenance practices, engine manufacturer quality control, shipbuilder practices and training, Josey said.
Northrop spokeswoman Margaret Mitchell-Jones said Friday in a statement that the company "is supporting the Navy in their analysis of the situation, however we defer any additional comment on commissioned ships to the Navy."
Homeported at Naval Station Norfolk, the ship was built in part with 7.5 tons of steel salvaged from the World Trade Center. The ship's Nov. 7 commissioning in New York City was the subject of much celebration and media attention.
Sun Jan 10, 2010 9:57 pm
This doesn't sound very good to me. The care and feeding of such important components during the long building process--several years---is the responsibility of the builder. Here's another opportunity for the taxpayor to pay through the nose.
Bunch of morons, what do they care? Freekin builders knew, this problem didn't just drop out of the sky.
IF I recall, that's why 'shake-down cruises' occur . . ...
I admit the news blurb is a bit vague but engine bearings are deep internaal components of large engines and should have been subject to strict quality controil inspections from the very begining of their installation.
No, this is not a shakedown cruise item...shakedown cruises are for integrating the ship and its new systems with its crew, not proving the installed gear is up to specs. That's a builder's trial thing that should not be necessary if the engines were assembled properly.
Not enough info in the blurb. Be interesting to see what the cause was. If it was inferior metal in the bearings, it will be REAL interesting to see the fallout. If the bearings have "Morton Thiokol" stamped on them......There'll be no joy in Mudville.
The onus is on NG and the Colt-Pielstick to fix it under warranty so in essence, we have already paid for it.
I take it you're thinking of STS-51L, the last government owned engine that had a part made by Morton Thiokol fail catastrophically? (In the purest sense of the word)
That'd be the one.
Yet another example why you should hire a surveyor even on a brand-new boat...Where's Al Prisco when you need him!
What does is cost to have a vessel that is 684 feet long with 4 turbocharged diesels surveryed?
I think Al quoted them 15 dollars a foot.:D
Actually the Navy has a Board of Inspection and Survey (INSURV) to do that. As I watch the military become as politically correct as D.C......This should be good.
There was a time years ago when i may have been considered for part of an inspection on a new ship like this. I have to wonder if pushing the machinery under testing could have created pre-mature excessive wear. Im sure there sampling the fluids often and will make repairs before to much damage is created.
I wonder what the warranty is, you would think the US Goverment could pretty much dictate what they want as far as warranty. Gees, even Silverton gives a two year bow to stern warranty.
New design, new ship, new problems. Shipbuilding is an art, not a science. In building prime movers of that size, you don't just drop off a few loads of steel alloys at one end of a factory and have a 20,000 HP engine come out the other end. Who knows who and where the bearings were cast? All it takes is a surge or bump in the power supply to the electric fired foundry to cause a problem during casting.
That would be in the contract requirements. If it wasn't then the requirements folks are in hot water and will probably end up with a promotion.
I worked for Lockheed-Martin for 14 years (then Martin-Marietta before the merger) in Orlando, Sand Lake Road plant. We inherited Northrop's CRAP on the Navy SLAT (Supersonic Low Altitude Target) program...garbage, both hardware and documentation...
How Northrop stayed in business, I'll never know...except the head honcho sucking the you know what of you know who...
Many years ago President Ike warned America of the dangers that might be found if the then young military-industrial organizations were allowed to grow without any control. Do a GOOGLE search if you don't personally recall this. We have suffered big time because no one listened to Ike.
If it is the rear main bearings this might even be due to bad shaft alignment. Perhaps someone aligned the shafts in dry dock and not in the water after the hullhad moved to the floating state.
Northrup GRumman has a history on multiple projects of this sort of failure and has been paid very well by the Pentagon to fix the problems. Most of them are on "black" programs so no one can tell that they happened.
I'd vote for shaft/bearing misalignment as well. The ship returned to Norfolk under power, if it was the crankshaft-bearings inside the engines they would have shut them down and waited for a tow. Shaft misalignment is common on new vessels as vibration isolators and other propulsion system support structure "settle-in". **** happens and they fix it, no big deal..... The primary symptom would be excessive vibration (and some hot bearings) which is a no-no on Naval ships built to run quietly.
