Engine Room Electrical Outlet
I would hard wire the block heaters each with it's own breaker. And add an outlet with it's own breaker for your trouble light, shop vac, etc.
My gas boat has a factory installed(at least I think it was) electrical outlet on the bulkhead on the front of the engine room. about 4 feet from the engines and about a foot from the floor. I had never had a surveryer question or say anything about it. Actually kind of hard to get to to be pluging anything in an out of. My water heater is pluged into it. you have to lay down and crawl a little under the floor that steps down to get to it. I don't see how it could spark unless you were plugging things in and out of it. Not the spark I would worry about it would be a fuel leak and a spark together.To get to the plug would be impossible without smelling fumes it there was a leak.
Anything plugged into the outlet could get loose and spark and the contacts could corrode and cause a spark.
It shouldn't have been a factory installation, but it's possible, Not every manufacturer has followed the best practices at all times.
If I were you, I would remove the outlet, remove the plug from the water heater cord, and hardwire it inside the box the outlet was in. Be sure to use proper strain relief on the water heater cable.
My gas boat also has a factory installed outlet in the engine room.
Our gas boat has three outlets mounted in the bilge, one being a 2x2 receptacle box that the 120V bilge pump and marine battery charger are plugged into, and the others are 1x2 receptacles for drop light use closer to the outboard sides of the motors where the engine room lights don't help much. Earlier this week, when reading this topic, and the discussions of only on diesel did I even think about this possibly being an issue. I had quelled my fears in my head by saying that the only way to plug/unplug anything from the outlets would require legit crawling around some good distances in the bilge where any fuel leak would be detected.... now I'm wondering again. Guess I need to reconsider.
Originally posted by jmeirhofer
Originally posted by caltexfla
I have a total of three in my two engine rooms, and put water resistant covers on them. For the block heater receptacles, i use a clear deep cover that has a slot at the bottom for items that are permanently plugged in. Sold at most hardware stores with any sort of electrical department, for out door applications. You are going to want the heaters on their own individual circuit breakers.
Are you saying each engine heater is on its own circuit? I had intended to put in one outlet and plug both into that outlet. For the occasion I would need an outlet in the engine room I would unplug one or the other or both if necessary. I do have several spare circuits with nothing on them and could do a separate one for each moter, I just did not think they drew that much.
It depends on what kind of block heater you are getting. The watts will tell you what to do. In my case, my immersion heaters are rated at 1000 watts each. While I have them on two different circuits partly because I have split ERs, I would give each of them their own breaker anyway for convenience when servicing and making it easier to figure out which one os tripping the breaker should the occasion arise. Hardwiring isn't such a bad idea either but I have been too lazy to get around to it.
My gas powered Tiara has an outlet in the engine room the charger plugs into, pretty sure was factory installed.
All these electrical outlets in gas engine rooms seems like an explosion waiting to happen
Caltex - I had not considered the ability to isolate by engine. I have plenty of spares so that is not a problem. Probably won't hard air though so I can use the plug for other things.
http://www.gpo.gov/fdsys/pkg/CFR-1999-title33-vol2/pdf/CFR-1999-title33-vol2-sec183-410.pdf The way I read the cfr, all appliance (which would incl outlet) installed in a gas ER need to be ignition proof. That would mean the outlet should be enclosed with a cover that prevents fume from entering the box.
I totally agree with that statement
Having the outlet should not be the problem. If I am in my engine room doing work (cockpit hatch has to be open for me get in) and I am using several different power tools, I normally run an extention cord and unplug/plug in a device as needed. There is no difference than if an outlet was hard wired in the engine room. Where there may a difference is that some owners may decide to put pigtails on equipment and plug them into the outlet instead of using crimps and a dedicated circuit to the AC panel. Using plugs does increase the risk of a spark which is a risk I'm not willing to take when the engine hatch is closed.
Hard wiring them allows you to use an outlet for other things while being able to keep the heaters on. Also each would be properly protected with it's own breaker.
Plus you wouldn't have to worry about them going off when you are not around due to a fault with the GFI outlet.
It doesn't matter if it was factory installed or not. It's a hazard.
If the appliance you are plugging into the outlet has no power switch or is already switched on, there will be sparks when you plug it in and when you unplug it. There will also be sparks as the electrical contacts in the outlet become corroded or weak. Sparks are what is dangerous around gasoline fumes.
The actual outlet won't create sparks, it's only a danger when you use the outlet. Of course, if you don't use it, there's no purpose in having it installed in the first place.
It's not really possible to make the outlet safe by putting a cover on it because once something is plugged I, there needs to be a hole for the power cord.
If you are comfortable with the risk of blowing your boat, your family, and yourself up, or if you subscribe to the theory that it hasn't blown up yet so it must be safe, leave it be and continue using it.
As I suggested above, a safer plan is to remove the outlet and hard wire the heater, charger, or whatever. This eliminates the risk.
RAWIDMAN,
I could not agree more. Very well said.
I think the philosophy is that you have to BE THERE to plug anything into the outlet, and if there are any gas fumes you'll SMELL them and act accordingly.
But we all know the world is full of idiots.
Several people have posted that they have battery chargers plugged into an engine room outlet. I think one said he had a water heater plugged into an outlet.
There is no good reason not to change these to hard wired and there are good reasons to do so.
Originally posted by GSENT
RAWIDMAN,
While I don't disagree that on the face of it having an open electrical outlet in the engine room of a gas powered boat would seem like a hazard, I can't help wondering if it was such a hazard why so many boat manufacturers would be doing it?
My guess is just plugging something into the outlet is much less of a hazard than plugging in and using non-ignition protected tools or equipment can be. And that can by done by using an extension cord that is plugged in off the boat in any case.
I think in both cases it comes down to using your nose(and or a fume detector)and a lot of common sense.
I can not believe that any manufacturer would install outlet in the ER of a gas boat and use them to feed chargers or water heaters... That makes no sense at all
These chargers and heaters have to have been added buy clueless POs.
Now having an outlet with a cover, as per the CFRs I cited, makes sense since it will be used temporarily and when not in use the cover make it ignition proof, as per the regs
An electrical outlet that's not in use will not spark and is not a hazard, cover or not. It's when you plug something into it that it becomes a hazard.
