Espar Marine Heaters
giolic
Anyne use or know someone who uses a deisel Fueled heater like an Espar ?
Mark
There are three types of diesel heaters: Stove type, forced air and hydronics diesel heaters. Espar makes forced air and hydronics. Which type are you looking at? There are thousands of these heaters in boats and industeral use. (such as in cabs in cranes or snowcats). I personally prefer a hydronics type of heater. I used a ProHeat modified for Marine use. The hydronics uses hot circulating water with both active and passive radiators thru out the boat. There is a fire box which heats the water and then a pump to circulate the water. The hose for the circulation of water is 3/4" and easy to pass thru the boat. Each cabin can have a radiator and small fan (12 volt) which comes on when the temperature drops below a certain level and shuts the fan off when the temp rises to the preset level. The passive radiators can be in closets and heads to keep clothes, floors and towels warm when the hot water circulates thru the pipes.
The force hot air is slightly cheaper, it uses large ducts and has to be balanced with dampers to get the air flow (simlar to the forced air furnace in the house). It is harder to install and less flexiable. Either system is far more effecient and better distribution than a "stove" type of heater.
I'll find out but here's all I know about it right now. " She is equipped with a $5,500.00 Espar heating system through the boat that is even plumbed into the engine compartment and thoughly heats the boat as needed."
mark
mark
Mark, I have a 55,000 BTU Espar ( hydronic) on my boat.
Not sure what the above statement means about being plumbed into the engine room? Mine is installed in the engine room (diesel fuel) there is no need for a duct as the radiant heat alone will warm the engine room from the furnace alone.
I do have it plumbed into my hot water tank so I can anchor out in winters and always have a supply of hot water available.
Depending on how many zones you have on your boat depends on how many thermotstats are used, this is a nice feature as you can really control the temperature. I also have defrost heat at the captains window to keep winter fogging away.
If you wanted to investigate what the 5,500 dollar Espar provides you I would ask the seller or broker how many BTU's this system has, how old is it? sometimes those diesel furnace exhaust pipes need to be replaced depending on age, How many zones it has , how many thermostats, does it have defrost etc. is it plumbed into the hot water system?
See if you can get a model number to comfirm what your being told.
The diesel heat is really a blessing on our boat and was high dollars to have installed.
You can more then double that figure you gave for what i have spent on our boat, but it sure makes winter boating a comfort.
Navman,
The guy didn't get back to me yet about the BTU's.
Here's what I got: The heating system is professionally plumbed through out the vessel with air ducks and via a fan system connected to a diesel heater. It costs the seller $6,000.00 it even heats the engine room via thermostat.
Thanks , Mark
It must be a dry heat furnace if heat is suppied with air ducts, although even my hydronic has some air ducting involved.
Depending on where you boat if it gets cold the heater will be a great option to have.
I have the forced air version in my boat really opens up the winter cruising window, The heat will drive you out of the boat on high ,I have twin gas but use a small gerry can with diesel p/up line in it, Mix 2/3 diesel 1/3 kerosene if you can have a seperate tank, burns really sweet with that mixture clean and hot. If on main engine diesel tank try to operate heater every 30 days to keep diesel fresh in lines and filters.
Here's what I got back form the broker. It sounds like an Option that would work well for Us. I might not instll one but it's a big plus when looking.
"It is an Espar D8LC. Air ducts are plumbed into all cabins, heads and engine room. Runs off main engine fuel tanks and even has its own 12 volt start and stop system. It is my understanding that it was installed by Ocean Options and cost $9,000.00,,, Yes forced hot air."
I will never pay to have one installed again, just cost to much. Next boat will have to have one , for us it is a must. The comfort of a warm boat in our climate keeps us boating year round. We spent a cold winters night anchored out in a local harbor , it was really neat to be able to do that without running a generator the entire time.
