Howdy folks. Been quite a while since I've frequented this fine forum.
I've got a question. My boat is a 92 Supra ski boat with a PCM 351 Ford. It is raw water cooled but has only seen freshwater. The boat has the original manifolds and risers on it, 22 years old. This afternoon I was getting the boat ready for the season and found the threads on the starboard manifold drain plug hole are pretty much gone and it will no longer hold the plug.
I plan to replace the starboard manifold. Incidentally. I have a pair of risers that I bought and never installed. I was replacing the exhaust hoses and the original ones looked decent so I kept them in service. That was about 6 years ago.
Should I buck up and go ahead and replace the portside manifold as preventative maintenance?
How many years can a person expect to get out of a set of manifolds and risers in freshwater only use?
Considering the potentially devastating consequences of a manifold leaking internally, would I be a fool for not spending the extra $230 to do both?
Thanks in advance,
DKJ
Thanks in advance,
DKJ
