Extending autopilot wires
praetorian
I want to move my Robertson AP200 autopilot from the salon to the bridge (not sure why it wasn't on the bridge always, but I bought it this way).
The wires aren't long enough to make it. I'll have to splice them and add wire. The problem is that it seems that there are a ton of wires inside the cable (~16) from what I can tell from the manual and the pinouts on the connector.
Is there some cable I can get that has that many wires inside it (I don't want to run 16 individual cables if I can help it).
Call Simrad Yachting or a dealer (maybe thru Les?) to order the length you need & you'll be all set with proper size and colors.
Making your own harness might not be a good idea because some of pairs may be twisted and others shielded. This is done to eliminate interference from power wires as well as cross-talk in the device. For the above reasons I would get one from the manufacture or a dealer otherwise it may work eradically if at all.
Take care. Bill
