Fiberglass Deck Repair
fountain27
Just received a call from my marina owner and in order to clean my gas tanks they had to drill two 6" holes in the deck. Can the fiberglass nonskid be repaired?
I believe they could have reached the sending units using an current access panel very close to where I believe they drilled the holes. However, until I see everything I cannot be 100% positive.
I am just very upset no one called me before drilling 6" holes in my deck. They filled the holes with those removable screw-in panels which will create a raised spot.
I do have the entire stern decking covered with carpet and I doubt the raise will make much difference.
Personally I'd leave the access panels in place. It will make it easy to clean them anytime you wish.
I had to do the same thing on my CC. I took the access panel off then taped the area. Put the access panel back on then scribed around it with a razor knife then a sharpie. Kept the tape tight then scribed it with a razor knife about 10 times. I was able to clean enough jelcoat away to recess the access panel just enough that it was not raised and it came out clean with no chipping.
I think however I would be very pissed too.
I would have thought that they would of cut holes to get to the pickup tube vs. the sending units especially if something was in the tank, there is a good chance whatever is in the pickup tubes also. I just went through this but the hole was cut into the floor of a locker.
Niles
