gw, congratulations !
you nailed it... problems started when low end builders (Searay, Bayliner, Carver, etc...) started trying to cut corners in the 80s to save $... they cut down on glass, tried using core below waterline etc... regardless of what one may think of david pascoe and yachtsurvey.com pictures don't lie. in the 90s, these builders started improving build quality and obvioulsy you can't judge todays' boat by what they built 20 years ago.
one big question mark, remain coring below water line. in my opinion, it's not worth it since you can never be sure that water is not in the core. A few years ago, i lost a transom screw in my previous boat... water came in and exited under the main cabin, not in the ER ! solid bottom, no harm done, but waht if if had been a cored bottom ?
This is great looking boat. as i've said before, when you look at some of these older boats, you got to wonder what builders learned in 30 years, besides styling which often gets in the way of "boatability". fellow RO MarioG has a 64 hatteras 34, i've seen the boat, it's incredibly spacious and far more usable than the typical 34 footer... for 1/10 of the cost.
these boats are worth spending a little money upgrading the interior, lightning, soft goods, etc... and turn them into head turning classics.
and the best part is that 2 years from now, that boat will not have depreciated whereas that new chlorox bottle will have cost its owner 50k in deprecation !!!
enjoy it !!
