Fiberglass repair?
Capt. Art
I found a small damage in my fiberglass right in the middle of my Bootstipe Line. If I use Marine Tex to fill it proud & sand it flush, can I just put a new Bootstripe over it? Does it need any further sealing or paint if it's not going to be seen unbder the Bootstripe? Looked like a small piece of splintered wood from the dock rubbed into the side of the boat. It's more then a scratch.
Marine Tex will do the job, Art. Have fun sanding the stuff, though:)
Still, it's probably the best stuf for small repairs, unless you have some of the matching gel coat for your boat's color.
Buzz
I've used the Marine Tex on many repairs but nothing this close to the Water Line. I just wanted to be sure this would never be a spot to allow water intrusion. Thanks for the help.
Marinetex is great but doens't owrk very well for cosmetic repairs.. it is VERY hard to sand!!
jsut get a little bit of regular epoxy and some lightweight filler, it will be easier to feather and sand.
Using marinetex for small repairs, grind out slightly(depending on the shape and size of the defect). Apply marinetex a 'scrape' excess away with spatula. moisten your finger with lacquer thinner and clean area and slightly depress marinerex to subsurface. After cure and roughen surface, use the paint to build back up.
Also, gelcoat can also be used to fill small scratches. After mixing, let sit in the open air a few moments til it 'flashes' (evaporates off solvents) so it thickens to a 'puddley' stage(balls up slightrly on the end of a small brush)...and 'puddle' it in. It's easier to sand...but gelcoat needs a rough surface for good adhesion.
I've used plastic wrap over a patch of silicon when it was still wet. Let the Saran Wrap stay until the area is completely cured, then gently pull off the wrap. Leaves a very smooth surface. Could this technique be used for MarineTex or other repair products on fibreglass/gel coat?
Comments?
It looks like I caught a luck break? What I thought was a damage to my fiberglass was only my Boot Stripe Decal bunched up from rubbing the dock. It left a wad of the decal appearing like a gash into the finish? They just hauled me out for the annual bottom job & Zincs (I stay in all Winter) so I got to feel & touch up close. A little 3M adhesive remover & a new Stripe is all I needed. Great news for a change.
