Filter for toilets
joyful
We have a 2000- 356 Aft cabin with two toilets.
I would like to install filters in the vent lines.
I can only locate one vent on the starboard side of the boat and suspect that both toilets are vented out of the single vent.
Any suggestions as to what type of fileters to use and where to install them?
Don Fitton
Hmmm.
I've not got a Carver, but your question is rather generic, sort of. You would almost certainly get a good response ifyou had posted in the sanitation forum, dedicaated to, among other things, the care and operation of a marine head.
Which, btw, is what your boat has: two heads, rather than toilets.
The vent almost certainly does not go from the head ( toilet ), but from the Holding Tank, of which you actually ( likely ) have only one of. Therefore you only have one vent.
I'll leave the rest, esp the bit on filters ( which I don't use, ever ) to others...
I do hope my answer has assisted you...
Bill is correct. You really need to post your question in the "Sanitation" forum. You will get a lot more expertise there.
One question though, what condition are you experiencing that leads you to ask this question?
2 heads, 2 vents on a 3607AC (different model). You might check the transom area for a second vent if you have a separate holding tank under the aft bed.
