Fire at Sea
saltysam
Most of you have already seen pictures of trhe damaged Japanese Destroyer after it collided with a large bulk carrier. Please take note that the forward 20-feet or so of the bow has suffered grave fire damage. Think for a moment and consider what caused this. Most likely it was a fire ( somehow started after the collision ) that ignited the boatswaine's storage area---the place where inflamable mateials abound. All that paint used for touch up work is often stored down there.
I suggest that boaters be aware of the damages caused by fires in closed areas usually thought to be "safe". Paint is notorious for causing much grief. Be Careful of inflamable material when you shove off for an afternoon's cruise.
You really shouldn't have it aboard.
Perhaps some of our active duty USCG folks can add to my comments ?
Usually the bow is the Boatswain's locker and is loaded with paints and solvents. They are stored in "paint Lockers" or on shelves.
For the Pleasure boater, these are usually not stored up in the bow. And usually the culprits are cleaning solvents and aerosol cans. And Hairspray makes a wonderful bomb...
What about the (in some cases) several hundred gallons of highly flamable GASOLINE most boats have onboard? A can of hair spray somewhat pales in comparison don't you think? I agree its not a good idea to store solvents and paints aboard. Those who use bottled propane for cooking take notice, talk about a bomb!
