I just recently asked a friend of mine about this. He's a fire fighter. His emailed response:
"At least once a year, turn it over and hold under your arm, and beat the bottom with a rubber mallet, then shake it really well. By law, there has to be a manufacturing date imprinted somewhere in the steel of the cylinder. The cylinders have to be pressure tested every 10 years (varies by state) and then refilled. Depending on how big they are you should do that. If they are smaller than 40BC, it is usually more economical to discharge them, then take them to the recycling center for the steel. Buy the LARGEST one you can afford (at least 2 40BC rated)."
