Hey guys! New to the forum and boating. I recently purchased a 1987 Thompson Daytona 290 with twin 3.7 mercs and Alpha I drives. Bought her from the original owner who was a boat mechanic and maintained the boat very well.
...and the story goes....
When I first inspected the boat both motors ran very well with the only thing needing attention was the shift cable on the port side. Going into forward the boat shut down.
I rebuilt the original helm with all new Faria gauges and re-ran some new wiring that was old and worn. With this I removed everything including old gauges, wiring, switches and remote controls.
... on and on and on and on .....
Now after the helm is back together I can't get the port engine to turn over (cranks fine), and I had coolant shoot from the exhaust port out the transom. I did a pressure check which revealed a loose hose, loose bolt allowing coolant to seep out and the heat exchange drain plug loose. Tightened everything up, drained the coolant and replaced with new. Pressure goes from 15 LBS to 12 LBS in 2 minutes time then slowly drops from there. The starboard engine will not engage in reverse and PSI drops from 15 to 13 slowly and remains there.
I beg of all of you to please help my sorry a**.
Thanks for reading and helping!
Joe
Joe
