Flir First Mate Info
bobn
My son is considering getting a Flir First Mate and wanted me to check and see if anyone has any experience good or bad with them.
Thanks for any info...
I can only vouch about the Navigator II unit with the joystick controller, fantastic. Great factory support my 1st unit failed within 2 weeks of the installation. I placed 1 phone call had an entire new unit the next day and was told to return my unit when the problem was resolved. Mine has been installed since the middle of last season. It is a great night cruising aid and reliable after I changed out the 1st unit. The 1st unit didn't totally fail it was stuck in white hot mode. The defect was not in the controller it was in the main imager unit.
A little of topic, but seeing FLIR (forward looking infra-red) / thermal imaging systems hit the civilian market is pretty cool. When my dad worked for the DoD in the 70's at Frankford Arsenal in Philly, they were working on proto-type thermal imaging systems which used liquid nitrogen as part of the system. When they filled the tank of the unit, it really looked like a mad scientist contraption. Sat on 2 carts 36x36x42 (if memory serves) with numerous cables attaching the detector to the display. When he retired and went to work for Martin-Marietta in the late 80s, he worked on the LANTIRN project (Low Altitude Navigation and Targeting Infra-Red for Night) which was originally tested on USAF F-15s. You test pilot are crazy, new technology, screaming through mountain passes at hundreds of miles an hour, at night...Civilian systems are simply amazing, small, compact, mostly reliable.
